#61
Old 12-19-2018, 10:05 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by krisr View Post
Half fill? Just to help keep the mains a bit more rigid or are you talking more full fill and run alky?
Filled to the bottom of the water pump holes.... seems to work best for us. We've went lower, approximately to the bottom of the middle freeze plug but that didn't help as much keeping the bottom of the bores round.
Go fast, see Elvis!
  #62
Old 12-19-2018, 10:11 PM
krisr's Avatar
krisr krisr is offline
Ahh cool. Mine is a '65 2xfreeze plug block, I filled to the bottom of those. I was surprised by how much filler went in because it wasn't far off the bottom of the front pump holes. Measured before/after the fill and my block must be possessed or something because no bores moved at all and the main tunnel didn't budge either. But it's good to know that the stock blocks with a bit of filler can be a good thing. Thanks Paul!
  #63
Old 12-19-2018, 10:14 PM
PAUL K's Avatar
You're welcome.... I'm glad I could help.
Go fast, see Elvis!
  #64
Old 12-20-2018, 03:19 PM
GTO JONES's Avatar
GTO JONES GTO JONES is offline
Originally Posted by hojs69 View Post
GTO JONES's
How many are running a 4.75 crank?
GTO Jones.......You are one of the few it appears.
I guess so ......
  #65
Old 01-08-2019, 06:53 PM
Mike Kasparian,Sr.'s Avatar
Mike Kasparian,Sr. Mike Kasparian,Sr. is offline
Pixs of main and rod journals on my Bryant crank . I am assuming the scoop on the main journal hole is on the leading edge in the direction of rotation to help oil entering the passage to rod bearing , correct ? Been looking into the main saddle groove along with crank journal chamfer .
ID:	502326   Click image for larger version
505 CID, 3560 lbs,Tiger heads, NA.
[email protected] mph, 1.29 60', stock suspension
  #66
Old 01-08-2019, 06:55 PM
Forgot , thanks for info Jeff .
  #67
Old 01-08-2019, 07:19 PM
tom s tom s is offline
Im going to SCAT tomorrow to pick up a 4in stroke crank.Will post how the dims look.Tom
  #68
Old 01-08-2019, 11:07 PM
https://m.youtube.com/watch?v=wK9odsWwfIo
  #69
Old 01-09-2019, 12:32 AM
Dragncar Dragncar is offline
That's some might nice looking steel there sir .
  #70
Old 01-09-2019, 12:39 AM
That IS what a well prepped crank SHOULD look like!
Dr. Thomas Sowell
  #71
Old 01-09-2019, 02:56 AM
It looks like they polished the whole thing. Pics of Molodex cranks don't look that good and they are known to be very tough.
Its a nice crank, I would be proud to have it.
Scat 4340 is going to have to be good enough for me. If KK can push 1400-1500HP thought one that plenty strong.
But if someone would make a fully counter weighted forging for 1500$ I bet they would sell.
If Ohio made some Pontiac billets for 2K they would sell some. 1600 gets you a Hemi Ohio billet.
  #72
Old 01-09-2019, 09:23 AM
The Bryant crank has Omicron finish from Shaftech .
  #73
Old 01-09-2019, 09:59 AM
slowbird's Avatar
slowbird slowbird is offline
Why did you have it sent to Shaftech?
  #74
Old 01-09-2019, 01:47 PM
Why not ? Nick does good work and its drivable for me . Is there something I should know ?
  #75
Old 01-09-2019, 02:23 PM
slowbird's Avatar
Lol, sorry didn't mean it like that.
  #76
Old 01-09-2019, 02:58 PM
No problem Brian , sent you a pm .
  #77
Old 01-09-2019, 03:16 PM
slowbird's Avatar
Didn't get a pm?
  #78
Old 01-09-2019, 07:20 PM
Picked up my Scat crank today,nice piece.I just did a quick check on the dims,checked the snout,one main and one J and called a machinist and they are good.One thing I found out is they will do a custom forged cranks,a lot more than off the shelf but they bring in raw forgings.I also found out they do custom billet cranks.Their metal comes from either Canada or UK.Did not ask price but they did say its about 14 week lead time.FWIW,Tom
  #79
Old 01-09-2019, 07:34 PM
Thanks Tom.
Back when I talked to Molnar he was clear that the foundry he uses wasn't USA. It was clear it was a different foundry than SG, RPM, Eagle, etc.
Hmmm ...
Dragncar, did he ever mention China or did we assume???
IMO If Scat or Molnar get the QC level they demand it shouldn't matter.
  #80
Old 01-09-2019, 07:50 PM
Their raw forgings are offshore for their custom forged cranks.Their billet material is not China,its from Canada or UK for custom billets.He told me if I wanted a custom forged 4in stroke 3in main crank with a pontiac J it would have to be custom as all their entry level forged cranks use a BBC J.Tom
