Old 02-20-2019, 02:26 PM
STEELCITYFIREBIRD's Avatar
Default I think my bird has a fungal infection?
SoI have 5% tint on my windows. Haven’t opened my doors in quite a while.
Here is what I was shocked to find when I opened doors and see what’s inside.
Help?
ID:	506137   Click image for larger version
ID:	506138   Click image for larger version
Old 02-20-2019, 02:37 PM
steve25 steve25 is online now
Yup I had that taking place in one of mine once from snow melt off thru the seal on my front windshield,in fact I had a 4 inch tall Musroom growing up / on my drivers front floor mat!
Old 02-20-2019, 02:41 PM
shaker455's Avatar
Wash it down hot water, soap, maybe quickly spray with superclean
Old 02-20-2019, 02:47 PM
JLMounce JLMounce is offline
Definitely looks like mold spores.
I would start by getting some ventilation in the car. roll the windows down even just slightly. You need to get it dried out in there.
I've never dealt with anything quite that bad, but you want to try and remove that mold/fungus without just spreading it around, as it'll come back. Hit your local car store and try an interior carpet cleaner. Those are a bit harsher as it's meant to deal with the crap on your feet etc. Work sections of the interior at a time and get this up as by doing it as dry as you can. Get some towels and scrub pads that you don't mind throwing away after. Instead of spraying the surface directly, spray the pad and whisk it out before applying to the interior. Spraying the material directly will just spread that stuff around.
You'll want to clean the carpets as well and you may need to take a peek under the carpet as you may have moisture buildup underneath that is contributing.
If you live in a humid climate, you can try a couple dehumidifiers made for guitar cases.
-Jason
1969 Pontiac Firebird
Old 02-20-2019, 02:51 PM
1funride 1funride is offline
When I was running a kerosene heater in my shop most of a winter, with my car doors closed tight I got a minor amount of fungi also. It did clean up rather easily and never returned. I blame it on the constant change in temperatures and a by product of an un-vented heater is moisture. In addition, the constant temperature cycles and not allowing it to breath is bad, it forms dampness on surfaces. I have since always left the windows cracked a bit. That seemed to solve the problem and lets it breath. Not sure if that is your case, but it was in mine. Clean it up, repeat as needed, use a good vinyl cleaner to recondition. If it comes back repeat. Dont use a chlorine based disinfectant for obvious reason. Something like Clorox Broad Spectrum Quaternary Disinfectant Cleaner may work and is bleach free (Amazon).
Old 02-20-2019, 02:54 PM
1funride brings up a good point about the windows. If the car is in a shelter of some sort where it's not open directly to the outside, it's good to keep those windows down a bit. Even in the winter, my windows are left partly down while the car isn't being used. Although we don't really have mold issues in Colorado as it's so dry, I always keep the windows at least cracked and typically put some dryer sheets on the floor boards.
-Jason
Old 02-20-2019, 03:28 PM
Default AND make sure you protect YOURSELF while you clean that crap out.
A good quality respirator, safety goggles or better a good chemical resistant hood, gloves, maybe even a surplus haz-mat suit.
And don't forget that those spores will be stuck to your clothing, shoes, cleaning tools, everything they touch. Either clean it all with bleach afterwards or burn it.
I've known several people who tried to clean out the 'black mold' junk that happens here in Vegas who got REALLY sick because the inhaled or ingested some small particles of what they were scrubbing off.
CLOROX is your friend when it comes to mold / fungus / germs.
Good luck!
Old 02-20-2019, 03:42 PM
67428HO 67428HO is offline
I had the same problem with a cool garage and high humidity in the summer. I wiped it down with 409 several times and put desiccant bags in the cars.
67428HO
Old 02-20-2019, 03:45 PM
tolerico tolerico is offline
Man that is too bad. Does not look good.
While I would not use bleach, get this product instead....
https://www.fiberlock.com/product/shockwave/
....and thoroughly clean the carpet (out of the car) and all vinyl surfaces. Clean the vents too as spores will be there. Not a good situation.
But you can get it back to being right. Your health will thank you in the end.
Old 02-20-2019, 03:49 PM
dataway's Avatar
dataway dataway is offline
I assume it was under a cover or in a garage? The UV in sunlight typically kills mold before it can spread.
Old 02-20-2019, 04:32 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Never thought I'd be glad to live in AZ. That really sucks! Never see stuff like that here.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 02-20-2019, 04:45 PM
bob d bob d is offline
Default fungal problem.
Joe's Garage is telling you some great info. mold in your lungs is bad. Thanks Bob.
Old 02-20-2019, 04:51 PM
dataway's Avatar
Might want to get yourself a mold killing UV light ... places like Amazon sell them. It should kill all the spores if you move it around to a few places. Exposure won't be long enough to damage plastic or cloth.
Or maybe park it in the sun with the windows down on some hot, sunny .. but low humidity days.
Old 02-20-2019, 06:10 PM
Mike S's Avatar
Mike S Mike S is offline
I use to have the same problem. Not that bad. I bought some desiccant bags that absorbed moister. I keep 4 of them under the seats. I forgot where I got them from. They where made just for cars in storage. I haven't had a problem since.
Old 02-20-2019, 09:08 PM
mgarblik mgarblik is offline
If you have a boating supply store in the area, see them. This type of mold/mildew is common on marine interior vinyl. Years ago, I bought a spray from a supply house like that and it was specifically for vinyl. Sprayed it on, waited a few minutes, wiped it off. Like it was never there. Sorry, I don't remember the name but again, quite common in marine situations. Should clean up. Then do something to keep the air moving and collect the moisture.
Old 02-20-2019, 09:24 PM
Grand73Am Grand73Am is offline
The marine vinyl cleaner sounds good if you can find it.
I have some of this, and it's the best I've used for removing mold and mildew. Works for everything around the house, including vinyl. I got it at Lowes, but Home Depot has it too. Doesn't cost much: https://www.lowes.com/pd/Home-Armor-...mover/50065733
Steve F.
Old 02-20-2019, 09:34 PM
Clean however per above. Find your leak (fromt or rear window, etc)
leave a window cracked open.
pray for a hot Summer & leave the windows closed on a HOT dry day once.
Old 02-20-2019, 09:45 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
I run a dehumidifier in my garage specifically for this problem.
Old 02-20-2019, 10:37 PM
Chris65LeMans's Avatar
Yuck. My condolences.
Old 02-21-2019, 07:12 AM
When I had that happen to my car the mold seemed to favor growing on the Armoralled areas more.
