#5361
Old 01-13-2019, 07:24 PM
Formulabruce's Avatar
The market for it is incredibly tiny. Its nothing that even shows. Good luck !
  #5362
Old 01-24-2019, 09:52 AM
sdbob sdbob is offline
Probably better to make. I could check I may have bought many back in 74.
  #5363
Old 01-25-2019, 09:44 AM
gilg gilg is offline
Default Preheater Duct Finish color
Hi Again need your advice about the correct preheater duct from manifold to air cleaner finish for 1974 Trans Am Super Duty the Silver finish or the Dark Grey i posted 2 pics with examples thanks
ID:	503824   Click image for larger version
  #5364
Old 01-25-2019, 11:35 AM
Red Goat's Avatar
Red Goat Red Goat is offline
The dark grey paper style is correct.
69 GTO 400, 4-Speed, Matador Red
69 SCJ Mach 1 Mustang, 4-Speed, Drag Pack
72 Trans Am, 455HO, 4-Speed, Lucerne Blue
73 Trans Am, SD-455, 4-Speed, Brewster Green
73 Formula, 455, 4-Speed, Ascot Silver
73 Formula, 455, Navaho Orange Survivor
  #5365
Old 01-25-2019, 02:25 PM
Old 02-04-2019, 10:32 PM
takid455 takid455 is offline
Send a message via AIM to takid455
Been in a small debate of recent. After 10 years of driving and enjoying my 74 in so called garage find patina, its time to adddress the patina. The debate it whether to shelve and make a display (table, lamp stand, ect) with the orginal black and build a different short block or just keep it all together. Top end will original sans roller cam upgrade. I don't keep things stock. This car has been and will continue to be enjoyed and driven as it should. Being the block essential IS the car, it would be ahame it it got hurt which is my only concern. Do others shelve these SD bloacks or send them and let it rip?
  #5367
Old 02-04-2019, 10:44 PM
RAIVJUMB's Avatar
RAIVJUMB RAIVJUMB is offline
My block is going back in, it is part of what makes it an sd.
Sent from my E6782 using Tapatalk
69 GTOx2
69 Judge CR 4SPD
70 RAIV Auto Judge
71 GT-37:usa2
71 T/A WHT AUTO
71 T/A LB 4SPD
72 T/A WHT 4spd
74 SD T/A Admiralty Blue Auto
others that reside in the barn too
  #5368
Old 02-05-2019, 12:51 PM
I drive my SD. It as 125,000 miles and has never been rebuilt. I drive the car but I don't beat it... though I'm not afraid to put my foot in it once in a while.
If your plan is to run the sh** out of it and beat it to death... you might want to find a different car..
  #5369
Old 02-05-2019, 01:17 PM
RAIVJUMB's Avatar
I think if you are going to drive it spirited then put it in if you are going to thrash it probably not a good idea and may be a better idea to either run a clone or another motor
69 GTOx2
69 Judge CR 4SPD
70 RAIV Auto Judge
71 GT-37:usa2
71 T/A WHT AUTO
71 T/A LB 4SPD
72 T/A WHT 4spd
  #5370
Old 02-05-2019, 09:53 PM
Spirited driving , yes. Floggin Molly, no. Appriciate the input. I'll come to a conclusion at some point in the near future.
1972 HO Trans Am auto White/white
1974 SD Trans Am 4 spd, no a/c dk blue/ white & blue
1978 Trans am gold/ black ,T56, t tops, EFI 474,
Build: http://www.pro-touring.com/showthrea...1978+g+machine
1999 30th Trans Am 6 spd, T top
  #5371
Old 02-14-2019, 12:41 PM
Hi looking its somebody have for 1974 T/A SD 455 SUPER DUTY the correct left hand valve cover front decal image from factory that show engine timing and engine code i attach few pics thanks again
ID:	505602   Click image for larger version
ID:	505603   Click image for larger version
ID:	505604   Click image for larger version
Name:	DSC03512 (1) 2.jpg
ID:	505605   Click image for larger version
  #5372
Old 02-14-2019, 03:49 PM
mscicluna007's Avatar
mscicluna007 mscicluna007 is offline
Is this what you are looking for. The picture you show is the assembly line block code sticker. This decal goes further back on the top of Rocker Cover.
https://rover.ebay.com/rover/0/0/0?m...2F183403742464
Sent from my SM-G930F using Tapatalk
  #5373
Old 02-14-2019, 04:39 PM
This is what I have, came from these forums I believe?
(probably this thread?)
These were different than 1973's I believe also.
  #5374
Old 02-14-2019, 04:43 PM
My mistake. I haven't seen that before.
  #5375
Old 02-15-2019, 06:52 PM
thanks but i think this is not for 1974 if i find one let you know.
  #5376
Old 02-16-2019, 12:02 PM
Held for Ransom's Avatar
Someone has a picture of it, I'm sure. But, I don't know if they'll show it.
Horst has a reproduction of his shown here...
http://www.pontiacpower.org/Emblems.htm
So long, farewell.
  #5377
Old 02-16-2019, 12:04 PM
I think Dick posted that one.
So long, farewell.
  #5378
Old 02-16-2019, 05:23 PM
SD Formula's Avatar
SD Formula SD Formula is offline
Having just completed an almost two year concourse restoration on my 74 SD Formula. I chose to improve some areas of the original SD engine such as, replacing the original cam with a Crane roller, Scorpian roller rockers/lifters, a Pypes SS System, and 70-1/2 through 72 operational shaker. A previous rebuild had .030 over Ross Pistons installed.
My SD will probably never be driven again, by me. I (sadly in some ways) have created a Trailer Queen that will probably be on the market in the future or be assigned to the family collection for the next generation to enjoy.
Although I'm extremely curious as to what these improvements will have done to engine performance, in terms of quarter mile times. The next caretaker will have to do that. I just hope I'm around to hear the results.
That said, I would do what I did almost 30 years ago when I first got this SD. Drive it hard, take it to the drag strip, probably get a couple of speeding tickets, but take care of it.
It's not an Super Duty with out that engine!
I might make a lamp out of the original camshaft & std TRW pistons. LOL!
PS. I will be showing my SD Formula for the first time since restoration, at the Amelia Island Fl. Concours d'Elegance, Cars and Coffee event on Saturday March 9, 2019.
When removing an unreplaceable washer, the part will be heard hitting the floor and then vanish from the face of the earth!
  #5379
Old 02-16-2019, 07:22 PM
I found another one in 73 SD455 restored and one in this forum
Name:	Saturday, February 16, 2019.jpg
ID:	505781   Click image for larger version
Name:	Full page photo.jpg
  #5380
Old 02-24-2019, 12:13 PM
bluebird455 bluebird455 is offline
Default 73 SD $$80k
Looks very nice, good price Imo.
https://www.ebay.com/itm/1973-Pontia...GM9B7xtZuewgmA
