Old 02-24-2019, 01:39 PM
Schurkey Schurkey is offline
Originally Posted by STEELCITYFIREBIRD View Post
When driving down the road I have 120*+ from the vents.
Yeah, I'd be peeved at lack-of-heat, too. If my heater was that cold, I'd suspect a failed thermostat.
My heaters typically run 160-170-ish. Depends some on inlet air temperature, and of course on thermostat rating.
If this were in MY driveway, I'd have an excuse to buy one of those vacuum-refilling cooling system tools. (Airlift or similar product.)
https://www.uview.com/index.cfm?dsp=...productid=5120
https://www.youtube.com/watch?v=mdFxiz8skaQ
The other hateful alternative is that you've got a failed head gasket or cracked casting that's putting a steady stream of combustion gasses into the cooling system.
