I've had old worn distributors before, and timing jumps all over the place which is why I can't imagine these guys didn't catch it back when I mentioned it was a likely cause. |
Eventually the reluctor wheel would have contacted the pickup hard enough to damage the pickup coil or shear a roll pin in the shaft. If you were lucky, the dizzy would fail and the engine would refuse to run. Worst case, it would have run until the oil pump shaft started to bind in the retainer loop that is cast into the block. That would really grind the driveshaft and make metal. If the distributor continued to operate, the oil pump shaft could bind up, twist out of position and fall into the crankshaft, with disastrous results. If you look at that oil pump shaft, you can see where it's got witness marks where its already dragging in the loop. The only time I've seen something like that, was out of my Pontiac 350 with a totally clapped-out HEI distributor. Glad everybody was paying attention to noises. This could have lunched the motor.
I could explain all this to the girl at the parts store, but she'd probably call the asylum. White '67 LeMans 407/TH350/Ford 3.89... RIP Red '67 LeMans. 407/TH400/Ford 3.25 Last edited by chiphead; 03-19-2019 at 10:33 AM. |
I've had this issue in the past, to the point that the rotor button actually makes contact with the cap and knocks the rotor button out of phase. Before the rotor button was bumped, it had erratic timing and was impossible to set correctly. I don't believe timing here was rock steady with a distributor that looked that bad. |
I'll call you grivera. After the news I got yesterday, I've been just trying to get my head straight.
Just to let you guys know...MSD stood by their product. They repaired the distributor at no charge and got it back to Paul already. I think thats awesome that they did that. I sent Paul a new distributor gear from Butlers. Hopefully I'll be enjoying this car soon!!!
| Closed Thread |
