#181
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
#182
The Batmobile just got a new utility Thanks to Scott P!!!!!!
Carburetor building & modification services Servicing the Pontiac community over 25 years |
#183
Hehehehe Looking good in the living room hood!!!
#184
Glad to see it go to a good home. Its been collecting dust in my garage for
FAR too long. -Scott
70 Bonneville convertible, Vortech V7 YSi supercharged EFI455 + 4L80E |
#185
A poet and he didn't know it!...lol
#186
Thanks Scott you will see it again... this season in my car.. maybe Kimball Farms.
#187
How do you all pronounce up "There", farms or fahms?
![]() Is that near Pepperidge Farms?
#188
Jeffrey, you are crazy!..haha!
#189
#190
That's "Down Mainer"
#191
Got brave today and drove her around a 3-5 miles radius.
Had my co-pilot with me today and fastest we hit was 40 mph. Carter afb carb is a piece of junk, can't wait for warmer weather to put Qjet on and P4B intake... Get some new paint on the valley pan. Going on lift to determine what suspension parts are new & old. Most likely will get upgraded springs & shocks to firm up the ride even though it has new KYB's in all corners. Scott P, I need to consult with you on suspension upgrades for sure! Can you or anyone please post links to upgrade.
#192
Not sure how I'm going to fit wider rims in the front... back looks no problem.
Up front, back of the wheel (Rally II), 6" wide 3-1/2" backspacing & tire 215/70-/15" are 3/4" away from the upper control arm now. I know Mark Cronk ran 255/40/17" 8" wide 4-1/2" back space all around on his...maybe he ground off some of the upper control arm?
#193
Put it up on lift today, mainly wheel bearing issues, rest of front end checks out fine.
Have to put new lower ball joint boots on and get it aligned. parts have been replaced and toe is in. Real lazy way to replace fuel line with nice stainless so pulled that out of the way of the spring.
Carburetor building & modification services Servicing the Pontiac community over 25 years Last edited by shaker455; 03-17-2019 at 01:24 PM. |
#194
Is that fuel line run through the spring? Oy . . .
I run 15x8 chevy pickup wheels on my '67 GP HT. 255/60-15 tires just rub a bit on the front fender, but no c-arm issues. This is with the 4-pot disk brakes.
Jim K in PA 1967 GP HT 428 1967 GP convert 428 1957 Chieftain 4D HT |
#195
Yes Jim that's how I got it...moved it out of way
That's good news on tires. Do you know what your back spacing is on you 8" wheel? Can I see some pics of you car & the wheel so I can ID which Chevy wheel/ Thanks Jeff Sent you PM
#196
If it's the regular 15X8 Chevrolet pickup rally wheel w/ 5 on 5 stud pattern....back spacing is 4-1/8! QUOTE=shaker455;6003900]Yes Jim that's how I got it...moved it out of way That's good news on tires. Do you know what your back spacing is on you 8" wheel? Can I see some pics of you car & the wheel so I can ID which Chevy wheel/ Thanks Jeff Sent you PM[/QUOTE]
#197
Overall width is 9-1/8 picture went fishing?
#198
I have the stock set to my 86' Stepside 4X4 but 6 lug
#199
#200
[ATTACH][/ATTACH]
TA DA! I'm done for now!
