Old 03-25-2019, 06:08 PM
Hillard's Avatar
Hillard Hillard is offline
Default Help identifying a 12 bolt diff
Can someone help me identify this differential? I've never tried or had a need to decode a rearend before, but I'm sure someone here has. I would appreciate the help, and if I need to find more numbers off of it, just tell me where to look. THANKS!!!
ID:	508867   Click image for larger version
ID:	508868   Click image for larger version
Old 03-25-2019, 06:24 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
This article is decent, short and sweet.
https://www.chevydiy.com/history-and...differentials/
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 03-25-2019, 06:25 PM
Probably a 1968 Chevelle 3.73 gear/posi rearend.
Old 03-25-2019, 06:41 PM
'68 "Chevelle" 12 bolts used the "124" casting center housings.
"038" casting 12bolt "chevelle" housing was used in '69 models. Malibus, Elco's, Chevelles, as well as '69 cast McKinnion c-clip axle A-body 12 bolt rears used in a few '69 Olds & Buick A-bodys. A very few late '69 production "038" casting 12 bolt rears ended up in very early '70 models, from what Ive pulled those were typically 2.73 single tracks.
Original axle tube stamping
CI 06 10 B
CI = 3.73 posi traction
06 = 6 month, June of '69
10 = 10th day
B = Buffalo diff plant
Old 03-25-2019, 06:45 PM
The article is also full of errors.
Old 03-25-2019, 07:24 PM
Hillard's Avatar
Thanks for the info guys. I can tell you it is a 3.73 posi. Wasn't sure it was original to the housing but I guess it is. So from the info above it looks like an late 69/ early 70 Chevelle. Thanks again.
Old 03-25-2019, 08:13 PM
F 2 8 = June 8th 1968
The CI 06 10 B is correct on being June 10th 2 days after being cast.
No year designation in the stamping.
That '8' could be a '9' but looks like eight to me?
Old 03-25-2019, 10:16 PM
Hillard's Avatar
I thought it was an 8 at first also. But that casting number keeps coming back as only used in 69.
Old 03-26-2019, 10:50 AM
Hillard's Avatar
Anyone want to give me your thoughts on what it's worth? It's complete with backing plates, minus the pinion yoke and nut. It's dirty outside, but internals look good.
Old 03-26-2019, 12:56 PM
GT182's Avatar
GT182 GT182 is offline
It could have been installed in 1968.... as in the last cars for "68" just before the change over to the new 1969 models. GM would run out of "68" parts and use what they had on hand.... new "69" parts so they could fill the last orders for "68" at that plant. And they'd still say 69 only.
Ford did the same thing too.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 03-26-2019, 04:00 PM
mgarblik mgarblik is offline
I had a 12 bolt, same ratio, posi for a 69 Camaro I sold at the Springfield, OH swap meet last year. It was totally disassembled, in a box but 100% complete. Housing was a little rusty, but not bad. The second the swap meet opened and before I had it completely out of the trailer, I sold it for $450.00. Could have easily sold for $600.00. But I wanted it gone, which is why I took it there. The guy who bought it acted like he won the lottery. That may be some gauge for you.
Old 03-26-2019, 08:08 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Wouldn't be the first time GM did that. My 3rd week of July '66 GTO has a '67 LH inner fender (for the larger '67 booster), 2 sets of bolt holes in the side frame rails (for the T-400), and I forgot what else...
Old 03-26-2019, 09:58 PM
Hillard's Avatar
Mike, from the asking prices I've been seeing, that was a steal for him.
Old 03-27-2019, 09:07 PM
Well, we were both happy that day. When I take stuff to a swap meet, it's to sell the stuff. Not to show it off and drag it home again. I hope it worked out for him.
Old 03-28-2019, 07:35 AM
JSPONT's Avatar
JSPONT JSPONT is offline
About 1.5 years ago, I sold my 3.42 posi 12 bolt from a 70 Chevelle. It had Moser axels and disc brakes. I put it on Craigslist, $1300.00. Next day a guy drove 150 miles each way, did not haggle handed me 1300 and left.
Old 03-28-2019, 07:48 AM
I have been running that sale through my mind from last year. I said it was 100% complete, and that was not correct. The assembly did not have ANY axle shafts, backing plates or brake parts. So it was housing, rear cover, center section, case/posi, all gears, bearings, caps, rear cover. So still a deal at $450.00. But $1300.00 for a complete Chevelle unit with disc brake set-up, Mosier axle shafts, and the desirable 3.42 ratio is also a good deal. I can understand why that guy was also excited.
Old 03-30-2019, 02:02 AM
Me too.
How does the 2 translate into the 8th? Not debating it, just trying to understand.
Sent from my moto g(6) play using Tapatalk
Old 03-30-2019, 07:12 AM
Should be Jun 2 1968
8 days before the housing stampings.
Had '8' on the brain I think.
The pertinent point is the 8 at the end which is for the year.
Old 03-30-2019, 02:38 PM
Held for Ransom's Avatar
Casting is F 2 9, June 2nd, 1969.
Without the yoke you can ask $1000 (although it may probably sell for less, around $800(Craigslist)). Around here anyways.
So long, farewell.
Old 03-30-2019, 11:21 PM
hgerhardt's Avatar
Is that June 2nd or 2nd week of June?
