Old 03-27-2019, 10:58 PM
Lightfoot's Avatar
Originally Posted by Goatracer1 View Post
Have you pulled a couple of plugs to see if the cylinders are getting any fuel? Too much fuel and flooded the plugs?
I had an '80 Lemans that would load the plugs at the drop of a hat when it was cold. Then it wouldn't start unless I took out all the plugs and dried them with a lighter. This was incidently the same Dual-Jet carb as OP, except on a 229 V-6.
I found out after owning the car for a couple years that there was a dry rotted vacuum hose on the carb that was causing the poor idle. Don't know why I never noticed it before then. I can't remember if it was for the choke pull-off, or something else. It idled like a champ after I put a new piece of hose on.
