#261
Whaaaaaaaaat? A&W on Lafayette? You did some detective work there! You sure you are in Arizona? My wife and I love to pound the pavement every chance we get. She actually got pulled over for doing a loud burnout with this car and the timing chain one tooth off! That's how good Pontiacs run folks! Everyone here already knows that. Bet you all can imagine how happy I am with finding that problem. Now I have back to back family events at our house. I had to quit wrenching on the Pontiac yesterday because I had to get the go karts ready to rumble. We have a big yard and 3 karts running around like a circus. Three sizes so everyone can have some fun. I will be able to finish putting it back together this morning and test drive maybe Monday. |
#262
I've read every page and admire your persistence! I know you are putting back together but second the advice of some others here to put a more appropriate sized cam in there to compliment the e-heads. This Crower 60916 would really wake up that engine:
https://www.summitracing.com/parts/c...SAAEgLJx_D_BwE
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
#263
Thanks for the 1.65 rocker and cam recommendations. They both sound like great ideas. It's getting really nice out here FINALLY and above all else we value our time behind the wheel. I usually do my upgrades in the off season.
#264
Good luck! Looking forward to your results!
#265
![]() If things go as planned I might move back in a few years to get some big yard.
"...ridge reamer and ring compressor? Do they have tools like that?" |
#266
![]() Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
#267
Here's a pic of the car WE were working on. Since that pic I put the factory ram air pans on it and opened the snouts.
#268
Here's a link to the Supercase; https://www.5speeds.com/case.html |
#269
You might consider the Voodoo 702
http://www.lunatipower.com/Product.aspx?id=1775&gid=287 The Crower 60916 with 278/289 advertised compared to the Voodoo 702 with 262/268 advertised duration. Both have similar .050" duration (within 2 degrees on the intake) and both ground with a 112 lobe separation. The voodoo cam has 132/140 degrees ar .200" but I'll suggest you will not get that information from Crower for that important evaluation, like comparing the duration between .050" tappet lift and .200" tappet lift. I didn't note the compression involved here. But note the Voodoo lobe has shorter seat timing and the all important additional valve lift over the Crower lobe, keeping this in mind where the cylinder heads will flow to. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
#270
VoodooTTFMF. Harold designed tech.
I fear the 702 could raise the cranking PSI over his current 190. Personally I'd lean to the 703. If I wanted 5500 RPM for a 400 engine I'd target .570 lift at the valve, the Voodoo gets ALOT closer. |
#271
If these are the correct numbers. The 703 might even raise his cranking compression.
Stan
#272
The Voodoo 703 cam card says 275/281 advertised.
May come to advertised rating lift and installed intake centerline. |
#273
Thinking that the catalog I have might be wrong. I went to Lunati's web site.
http://www.lunatipower.com/Product.aspx?id=1776 Isn't this the 703? If so why would the cam cam have different numbers then the catalog and web site? Stan
#274
Cam spec card lookup for the previous part number: 60903
http://www.lunatipower.com/CamSpecCa...rtNumber=60903 .
#275
I had a little time early this morning to try it out.
Runs like it's a tooth off on the chain. Can even get it to idle now. Checked, double checked, and triple checked the plug wires and they are on in order. It used to idle real nice. What could be going on? |
#277
Where did you set the distrib timing?
#279
I have an idea of what it might be. I'm going to wait and see what you guys think first.
#280
Tried it all over the place just to get it warmed up. The best I could attain with moving it around was a very rough idle. Way out of time.
