#381
Old 04-08-2019, 03:26 PM
TAQuest TAQuest is offline
Balancer is like new. Thanks.
  #382
Old 04-08-2019, 03:27 PM
New cam, new valve adjustment. Sometime in the near future.
  #383
Old 04-08-2019, 03:31 PM
Sticking with the 1.5 roller rockers.
Is it the Voodoo 2 or 3?
Which valve springs are recommended for this?
Old 04-08-2019, 03:50 PM
max 93 max 93 is offline
Is there a phone number on the receipts that you can call and verify the parts?
  #385
Old 04-08-2019, 04:01 PM
Stan Weiss's Avatar
One problem I would have with recommending a cam is I have no idea what the engine's CR is.
Stan
Pontiac Pump Gas List
  #386
Old 04-08-2019, 04:10 PM
Stan
Stan you're a pretty smart guy with all those formulas. Can't you take the known cranking compression along with the know cam in the engine and reverse engineer that to a static compression ratio with one of those fancy formulas???
I'm just thinking out loud, lol.
  #387
Old 04-08-2019, 04:18 PM
On a more serious note, based off knowing we have a 400 with high cranking compression already, and knowing the cam is really small at 204/214 @ .050, and since it's a 4 speed, I'd probably want to jump at least 15 degrees in duration, which would still be very docile to drive.
I wouldn't have any second thoughts of going to either a voodoo 702 or the Crower 60916
  #388
Old 04-08-2019, 04:22 PM
Stan Weiss's Avatar
Been there, done that! post # 298
If the cam in the engine is the Edelbrock listed in the specs. Then 215 psi cranking compression CR would be about 10.7:1. With 190 psi cranking compression CR would be about 9.7:1.
The problem is the engine did not run right at either place. So why would I conclude either one was correct.
Stan
  #389
Old 04-08-2019, 04:27 PM
I'm just poking fun at you Stan
After 20 pages of this, and knowing I'm pretty confident that I as well as a couple others had it figured for too much cranking compression to use pump gas from the get go anyway, I knew a cam swap was going to be in order at the end of the day. I'm not going back through to read it all, lol.
  #390
Old 04-08-2019, 04:35 PM
Stan Weiss's Avatar
In case anyone would like to play what if games this might help.
Stan
  #391
Old 04-08-2019, 04:46 PM
pastry_chef's Avatar
x2
Even knowing what measured intake centerline generated what PSI would be a great help.
  #392
Old 04-08-2019, 05:45 PM
I asked the people who took over the business and he said it was a standard stroke Pontiac 400.
  #393
kyle_blake's Avatar
kyle_blake kyle_blake is offline
Since your're getting a new cam and timing chain set with instructions hopefully with tdc verified and right timing cover balancer referenced all works out. when you break in camshaft you will want to stab the distributor 10 degrees advanced and when cranking to break in camshaft have someone on distributor ready to turn it as required to get it fired. alas one step at a time. this requires the some more work but she's a nice looking car and worth it.
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
  #394
Old 04-08-2019, 05:47 PM
Nice. Thanks.
What about the springs for these Edelbrock heads to match that '702 or the 60916?
  #395
Old 04-08-2019, 05:49 PM
Thanks.
  #396
Old 04-08-2019, 05:59 PM
NeighborsComplaint's Avatar
Does it rev past 3200RPM in neutral/park? Hate to ask the obvious but does it bog only when driving without an air cleaner?
Triple Black 1971 GTO
  #397
Old 04-08-2019, 06:00 PM
That was just a guess on my part, but why I said 10.75
Head Gasket Thickness = 0.028"
Head Gasket Bore = 4.160"
Combustion Chamber Volume = 72 cc's
Dome Volume = -7 cc's
Zero Deck
CR = 10.752
Stan
Was this correct? With L2262FSTD pistons? With standard block?
  #398
Old 04-08-2019, 06:01 PM
All the time. Very consistent. Same thing at same rpm. Nothing external changed a thing.
  #399
Old 04-08-2019, 06:44 PM
Stan Weiss's Avatar
Head Gasket Thickness = 0.028" * * *
Head Gasket Bore = 4.160" * * *
Zero Deck * * *
CR = 10.752 <<<<< This is just calculated from above
Stan
These items were just guesses * * *. Would you have any idea what would be closer to the real numbers?
Stan
  #400
Old 04-08-2019, 07:15 PM
Stan
What if it was not decked, what would it be?
