Old 04-09-2019, 12:48 PM
Stan Weiss's Avatar
Originally Posted by TAQuest View Post
Why? I don't know. If it was cam related then we will be fixing that. If it was not then we will fix that too. Cam first. One rock out of the field at a time.
Just saying what I would do if it was my field and my rocks. lol
But it is your field and your rocks. Good Luck
Stan
Pontiac Pump Gas List
Old 04-09-2019, 01:16 PM
TAQuest TAQuest is offline
Stan
Yup.
Maybe a $17 timing set from a warehouse that would close soon after they sold it was funky and the dots were wrong? Or the cam was ground wrong.? Hang your hat on that rather than thinking that all the mechanics working on the engine were wrong.
Old 04-09-2019, 07:01 PM
SA74SD SA74SD is offline
I've tried following this for over 450 replies. I do recall two things by the OP.
36 degrees total timing and never uses a timing light, times by ear.
A degree wheel and confirmed TDC would put the guesswork on that cam to an end.
I wish you luck and success.
Old 04-09-2019, 07:06 PM
A degree wheel while it's in the car? hmmm
I'm going to settle for the piston stop I made earlier and a marked up balancer.
To each his own.
Old 04-09-2019, 07:21 PM
pastry_chef's Avatar
If the cam will be a Voodoo 703 then the intake lobe should very close to .075 lobe lift at TDC when installed, maybe a few thou more.
Old 04-09-2019, 09:50 PM
Degree wheel can be used in the car, just a little more tedious and time consuming. I've done several "in car" cam swaps using a degree wheel. Everything you have to remove out of the way to slide the cam out gives you the room needed to use the degree wheel. Just sucks laying over the fenders trying to use it.
Old 04-09-2019, 10:31 PM
Steve C. Steve C. is offline
"Caught the order before it left the warehouse and changed to this cam."
And with the cam you will need to upgrade the valve springs. And yes, I know I already mentioned that.
Old information here:
