Old 04-10-2019, 02:02 PM
RocktimusPryme's Avatar
Originally Posted by Inogame View Post
I used these, marketed for Chevelles but are white LED halo with original style glass.
http://www.chevelle.com/1964-1970-Ha...hts-P7969.aspx
Install was simple and when the Halo is not on you cannot tell they are anything but stock.
This link was the article where I found out about the headlights -
http://www.superchevy.com/how-to/pai...ssic-chevelle/
I don't have a great pic of them on, but I attached the best one I could find here at the office. They look really nice even if my pic is terrible.
Totally ignorant question but how does the halo effect work? Is it a separate switch? Or is it haloed when you turn the lights on.
Old 04-10-2019, 02:33 PM
Inogame Inogame is offline
I have them tied into the running lights so they come on when I pull the headlight switch back halfway.
There is a separate wire in each bulb for the halo, you could tie it to a switch if you wanted. they are LEDs so very little volt/amp pull.
I'm not an electrical wizard, but I feel like there would be many options depending on what you wanted to do.
The regular bulbs work no different than the normal light harness, same connections as stock.
Old 04-10-2019, 02:38 PM
Oh okay, so they are only cosmetic, don't add any light to night drivability. If you don't want to hook them up just don't provide power to that separate wire.
Old 05-01-2019, 08:35 AM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
Actually halos can work as DRLs like on most new cars. I plan on using switchback halos on my 67. These also act as amber turn signals. I'll use the high beam bulbs for this. If you see a new challenger or charger they use this type of setup. I'll wire the factory signals to be on when I turn on the headlights.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
