I understand that. But you still don't know what it was and if that was the problem. The Pontiac 066 cam was stamped with an N.
Stan
Measure lobe height now that it's out of the engine. Post a pic of the lobes...041's are pretty bullish over the nose.
Clay |
These figures are two separate hand stamped letters because they are not in perfect alignment with each other. It is an I and a V.
Maybe elementary to you ....but I’ll ask; Your sure crank was on TDC thruout all your cam timing checks? |
I didn't degree the cam that was in it. I will be doing checks on the new one.
