What did you do to fix the 455? Did you degree the cam to make sure it wasn't some sort of custom grind that made it work better with the marks not lined up? Last edited by TAQuest; 04-11-2019 at 11:56 AM. |
Tore it down and set the gears/chain dots up and verified valve events during overlap by marking the balancer. Used the balancer like a mini degree wheel. Did that before putting the timing cover back. Used a piece of coat hanger and a short bolt to make a pointer. Middle timing cover bolt hole held the pointer just right for the balancer's O.D.. It took major carb tweaking, mixture screws and idle speed, for it to run at idle. Valve events happening at the wrong time had adjustments way off. Picture intake valve opening happened early in the exhaust stroke instead of where it should have been during overlap. Exhaust pressure kept all the fuel/air from going in during intake. The exhaust pressure made the carb moan loud and stopped the engine from reving. Where the engine should have been making peak torque...It was starved for fuel/air and couldn't rev any higher. Nothing custom about this. Just a mistake by the builder. That help explain.. I wasn't trying to argue or be stubborn earlier in the thread. Just trying to get you to understand. Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
