Old 04-29-2019, 07:55 AM
STEELCITYFIREBIRD's Avatar
Curious if you mapped out your timing curve?
More initial, and less in the dizzy/total may clear up you spark knock issue, and increase low end torque. Some more fuel also.
If your around 10:1, your in the right range compression wise for aluminum heads and should be able to tune for 93 pump gas. Also may need to limit amount of vacuum advance and tune where it comes in.
What you have and where the knock is (assuming light load low rpm tip in).... If it knocks wide open, you may be after much more than a cam on your next parts order.
Every one is trying to help you get it humming, don't take the advice as insults.... A lot of good experience to draw from here.
Like a hot body...if it came in a box everyone would have one.
I understand and will consider this closed if your done trying to get it better with what you got.
Old 04-29-2019, 08:02 AM
pastry_chef's Avatar
Having tuned at least 3 E carbs with performance cams, one with a wideband. The factory calibration isn't going to cut it.
I see this as well.
Old 04-29-2019, 08:05 AM
TAQuest TAQuest is offline
I see this as well.
Thanks for that negative response. Maybe you should think about why you post here. If you aren't posting to help then you are posting for the wrong reasons.
Old 04-29-2019, 11:17 AM
Stan Weiss's Avatar
This thread is like a train wreck that one can not stop looking at.
Just changing cams again is not the answer.
When the original Edelbrock cam had its phasing changed. Do not know if it was then exactly correct but it was much closer to correct then when you started. You said you could not get it to run right. That was the point to find out what was really wrong.
Stan
Pontiac Pump Gas List
Old 04-29-2019, 11:23 AM
Stan
I posted all about why it didn't run. It's not an issue anymore.
Old 04-29-2019, 08:03 AM
More initial, and less in the dizzy may clear up you spark knock issue, and increase low end torque. Some more fuel also.
What you have and where the knock is (assuming light load low rpm tip in).... If it knocks wide open, you may be after more than a cam on your next parts order.
Every one is trying to help you get it humming, don't take the advice as insults.... A lot of experience to draw from here.
Yes, a little less advance and it will spark knock less. I wanted it advanced to get the whole big cam experience.
The tick is lifters. If it's something else then I will be fixing something else some day, of course, doesn't that go without saying?
Looking back, the only comments that really helped at all mostly came from Clay.
Not saying that others weren't trying to help, their comments didn't help. Mostly condescending.
You helped me make sure my pushrods were the right length, thanks.
There's a lot of 'noise' around here that's not very positive. Sorry folks are not happy. Glad I have a life that keeps me positive and moving forward.
