#261
Old 05-05-2019, 07:22 PM
tom s tom s is offline
If there is any spark knock that is not good!Tom
  #262
Old 05-06-2019, 07:31 AM
A lot 'less' spark knock 'this' time? There was spark knock the last time?
Just to say, there is such a thing as 'inaudible det', which can be just as dangerous.
Trying to help is all, and good you are happy with it now.
  #263
Old 05-06-2019, 10:54 AM
Doubt you'll get him to read plugs for spark knock when he won't even use a timing light, he times it by ear
Yes I'd say with cranking compression of 200+ before with this same cam, and running pump gas, there was most likely spark knock before, he was likely unaware of it. He may like how it drives since a baby cam like this would require no tuning at all for smooth operation but it'll take a while for him to find out that any detonation will come back to bite him if he drives the car enough.
  #264
Old 05-06-2019, 11:35 AM
TAQuest TAQuest is offline
Troll
  #265
Old 05-06-2019, 11:41 AM
You have no clue.
  #266
Old 05-06-2019, 11:46 AM
You have no clue.
It’s obvious you are not genuinely trying to help. So then you are trolling. Get a life.
  #267
Old 05-06-2019, 11:53 AM
I guess you missed the other 50 pages of everyone trying to help, myself included. But you can only do so much on these computers. Quite frankly when it gets more involved I prefer the car here in front of me as it gets too in depth for most to understand, and this was a perfect example of that. I think you got the best help that could be expected from everyone here given the circumstances. You can lead a horse to water but......
  #268
Old 05-06-2019, 11:55 AM
With all due respect many have been trying to help.Many have asked if you pumped the engine!If it pumps over 180 you could have a problem with pump gas.As said audible is not good at all and you could also have in audible detonation which over time can knock the bearings out of the engine.Good luck with your project.Tom
  #269
Old 05-06-2019, 11:58 AM
Just not in a position to give a compression check right now.
  #270
Old 05-06-2019, 11:59 AM
Have the tranny off.
  #271
Old 05-06-2019, 12:02 PM
Agree Tom, and I hope it works out for him as much as the next guy. Tons of knowledge in here if one chooses to listen. But if he doesn't want to pump the engine again, check plugs, or set the timing with a light, and if this thing has high cylinder pressure again, he may find out later down the road what we've been talking about. Especially the way that engine gets loaded with a 2.20 first gear and 3.36's out back. Yikes.
  #272
Old 05-06-2019, 12:08 PM
I set it with a light then corrected it by ear. I’m sure it’s exactly where it would be if would have just done it by ear.
  #273
Old 05-06-2019, 12:24 PM
242177P's Avatar
242177P 242177P is offline
You might not like it, but Formulajones said what needed to be said. Patting you on the head does not help you, it just makes things worse.
  #274
Old 05-06-2019, 12:39 PM
Stan Weiss's Avatar
Since you have the trans out. What are you going with as far as clutch and pressure plate? My guess would be they were both new with the engine build. So are they now worn out or can they not how the torque the engine is making?
Stan
Pontiac Pump Gas List
  #275
Old 05-06-2019, 02:03 PM
Dots up with original cam he posted 190 psi.
Should be the same now. Would be interesting to see if it did change. Cam grind changed a little. Or timing sets not made exactly the same.
Cam out of time it needed octane boost.
Voodoo cam made more running compression and needed more octane boost.
Should need less now than in all the past years that he's drove it.
Clay
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
  #276
Old 05-06-2019, 02:14 PM
STEELCITYFIREBIRD's Avatar
We put numbers to settings and tests , data, to compare to known norms , and allow us to duplicate those settings after servicing.
Or if a malfunction occurs, to check if a setting is off from your set point. Ear and eye data is hard to quantify!
You were checking/adjusting cam and ignition timing ...without a TDC reference point when this crazy train left the station..
  #277
Old 05-06-2019, 02:40 PM
Post #517 and #518 in the other thread. Your question and his response.
Clay
  #278
Old 05-06-2019, 03:14 PM
Clay
Spot on again. Thanks
  #279
Old 05-06-2019, 04:16 PM
Stan Weiss's Avatar
Clay
X2
Clearly as you said there are a number of reasons that it will not be the same.
Stan
  #280
Old 05-07-2019, 10:39 AM
Stan
Either way the answer was a new clutch. I’m going with a Mccloud 100.
