Old 05-06-2019, 04:10 PM
Sirrotica's Avatar
Full flow oil filters speced for a Pontiac Stratostreak V8 do not have internal by pass valves. The one in the oil filter elbow is the only safeguard in the oil system. Blocking that safeguard allows no bypass whatsoever. If the filter cannot handle full flow at high RPM is will do one of three things, leak externally at the sealing O ring, blow the canister out rupturing it, or collapse the filter media internally, possibly ripping holes in it. Unless you cut open each filter you'll never know if it collapsed the media rupturing it, rendering the filter in by pass mode 100% of the time. If the system overpressures the oil filter it will find the weakest link.
Smokey Yunick calculated that a SBC would need 4, 12 inch long full flow filters at full RPM to filter all the oil pumped through the engine. Anyone here with a blocked by pass have anywhere near that filter capacity?
There are much safer ways to filter the oil to a higher standard than any full flow filter or combination of multiple full flow filters do, usually on PY this all falls on deaf ears, as I expect it will currently....
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 05-06-2019, 04:22 PM
Yeah we know. I don't think it falls on deaf ears, at least not some of us. But as much as I like what a by pass filter does and how well they work, (trust me, I'm an Amsoil user and they really push those filtration systems) most of us can't or won't put them on these classic cars. They either can't be fitted neatly and/or hidden on some cars where you don't want to look at something like that on a nicely restored car.
So we have to resort to frequent changes and try to keep things as clean as possible.
Closed Thread
