I would disagree with that statement. I've made many engines quit detonating by advancing their cams. Instead, I would restate that comment as the biggest factor in detonation would be the valve opening difference between the intake valve and the exhaust valve at TDC during overlap. Retarding the cam causes the exhaust valve to be open more, and the intake open less at TDC so when the piston starts down the hole, for the first few degrees it is sucking harder on the exhaust port and trying to suck hot exhaust gasses back in which I feel are the main ingredient for detonating. I like to see the intake valve open between .035 and .040" more than the exhaust at TDC during overlap on 110° LSA cams. Wider lobe seps will bring these numbers closer so with 112 LSA the difference will be more like .025"-.035". If your exhaust valve is open close to the same amount as the intake at TDC during overlap, then your engine will almost certainly detonate without low compression. Looking at it this way, I have built quite a few 10:1+ iron headed engines that ran fine on 91.
Agree if an engine has issue with residual exhaust, advancing the cam can help reversion. Advancing also opens the exhaust valve earlier.
Magnum intake lobe 5241 / exhaust lobe 5204 236 / 244 112 LSA - 108 IC / 116 EC 1.65 rocker. lift at TDC overlap. intake .137 exhaust .114 -------------------------- intake lobe 5241 / exhaust lobe 5204 108 LSA - 104 IC / 112 EC 1.65 rocker lift at TDC overlap. intake .161 exhaust .129 With 112 LSA and 111 intake centerline the lifts at TDC are close to the same. Straight-up at 112 IC the exhaust has more lift. UDHarold - Dec 19, 2005 Quote:
