Old 06-02-2019, 10:17 AM
mgarblik mgarblik is offline
Originally Posted by 535 tall deck View Post
The more I think about it I believe he made a cap/main girdle set up
We are going back nearly 10 years here, but I think that set-up actually produced in metal was for an Oldsmobile V-8. If my memory serves Mr. Anderson was working with Cody, (last name?) at Joe Mondello Racing Engines and they had cut that unit out for Oldsmobile installation. I do remember him posting somewhere a similar unit for a Pontiac in a CAD format of some type. But not sure if one was ever made. Steve Barcak and a couple other guys have made multi-piece reinforcement girdles for Pontiac blocks. As an engine machinist, I like the multi-piece design from a service standpoint. Having a one-piece girdle/main cap bridge is a complete nightmare when it comes time to line bore/hone the mains. Conventional engine machining equipment can't handle a piece like this. Now your into CNC machining for routine service. A deep skirted block with 7/16" or 1/2" cross bolts and individual caps would be the best for strength and service. For big HP, a stock design Pontiac block just doesn't have the material in the right places to create the best possible lower end. If you use 9/16" fasteners in the center bolt holes, there is very little material left to hold them. The outer splayed holes as well if large fasteners are used, very little material to hold them. A much smaller main bearing would help by allowing more material around them to hold the caps. The original 180 HP design from 1955 has it's limits. The 3000 HP a few are making out there is probably close.
Old 06-02-2019, 10:56 AM
slowbird's Avatar
slowbird slowbird is offline
How small of a main you wanting? Curious what will live at these high loads?
Old 06-02-2019, 11:37 AM
[QUOTE=slowbird;6028636]How small of a main you wanting? Curious what will live at these high loads?[/QUOTE
2.75 (bbc) mains are used in fuel applications...
