Old 06-18-2019, 02:41 PM
Va68goat's Avatar
Va68goat Va68goat is offline
Default Update
The motor should be here before the weekend!! Next update will be the motor running!!!!
Old 06-18-2019, 06:57 PM
cnc's Avatar
cnc cnc is offline
Nice ....video video video......
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 06-24-2019, 08:57 PM
Va68goat's Avatar
Here's a clearer version of the dyno sheet.
Name:	NEW dyno pg 2 copy.jpg
ID:	514774   Click image for larger version
Name:	NEW dyno pg 1.jpg
Old 06-18-2019, 06:58 PM
cnc's Avatar
cnc cnc is offline
Nice ....Road art ........video video video......
Old 06-24-2019, 05:03 PM
Va68goat's Avatar
proximity_alrt,
The motor is in my garage now. I've never dropped a motor and bolted it in before so I think it's best for me to wait until one of my buddies help me. Hopefully we'll get this thing running in a few weeks!
As for the dyno...I have no idea what went wrong. The date and time is wrong, the rpm numbers are off the page, I was told the dyno guy makes up names for Jeff's carbs but apparently there is such thing as a 850 Brawler, the oil temperature gauge wasn't hooked up, it seems like the last dyno numbers are much different then the dyno run in September of 2017. Hell, I have no idea how to even read the dyno sheet.
Old 06-24-2019, 11:32 PM
craigs69's Avatar
craigs69 craigs69 is offline
proximity_alrt,
I wish we lived closer, Joe. I would come over and get that engine in this weekend.
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds.
Old 07-14-2019, 10:28 PM
Va68goat's Avatar
Well...we started the motor today and the same knocking / ticking noise is present. To say I'm disappointed is an understandment. Does anyone have any ideas or thoughts?
https://www.youtube.com/watch?v=To57VTU11xM
Old 07-15-2019, 05:10 AM
krisr's Avatar
krisr krisr is offline
sounds very mechanical. Did you try it without the converter connected?
Old 07-15-2019, 10:27 PM
Va68goat's Avatar
TedRamAirII,
With Paul finding the bad distributor bushing after we located the witness marks are the oil pump shaft, we thought for sure that was the issue. This motor was on the dyno a month ago and it still has the same noise as before. We've done the wooden stick, long screwdriver and even a mechanics stethoscope. We thought we had a signature at the distributor. Nobody can understand why the motor is reported to have been running good on the dyno but yet bad in the car. We didn't touch the timing or adjust the carb prior the starting the car. Before I sent the motor back, we ran it without the belts..noise was still present. The balancer was torqued by Paul so I'm positive it's correct. We will check it but the noise has always remained the same. Pulley bolts were tight and we didnt get a signature from the fuel pump. We even ran the motor with the fuel from just the bowls and the knocking never left. We felt the dipstick and it was fine...no vibration or marks on the dipstick. As for the distributor...it was reported that the bushing went bad on the MSD ready to run distributor. I've done months of research to find another case of an MSD distributor bushing going bad and I couldn't find another complaint. Distributor cap was fine. Paul had it in his hands when he discoverd the bad bushing.
Is it even possible that the distributor was severely damaged when the motor blew up on the dyno because the pickup tube fell into the pan? What exactly happens? Is that a violent failure or does the motor just die a slow death?
Old 07-15-2019, 10:41 PM
Scott Stoneburg's Avatar
I agree with TedRamAir. Get your hands on the motor to feel for the noise. I would get the car in the air enough to get under it. On stands or ramps. A lift would be best. Take all the belts off so there are no external accessories being driven. You wont run it long enough to overheat it. Get under it and put your hands on the pan. Use some sort of stethoscope tool to listen for it.
You running 1.5 rockers or 1.65?
Old 07-02-2019, 03:20 PM
Va68goat's Avatar
64speed,
Hahahaha. I agree 100% with you. I'm sick of this thread. I need to be ripping these tires apart. No more updates...unless I have a question on how to do something. Standby for the next "update" post. That will either be the 1st start video..or lighting up these tires that only have 200 miles on them.
cnc,
Thanks. I'm looking forward to it!
Old 07-15-2019, 12:00 PM
Va68goat's Avatar
Formulajones,
Again, you're a great friend to Paul and Jeff and I expect no less. I won't acknowledge your comments on this thread anymore because you're just a distraction and you're not contributing to solving the problem. You're not part of this equation so there is no use in you commenting. Me, Paul and Jeff are bummed about this and the last thing any of us need is someone that is trolling. Either help solve the problem or move on to another thread!
PS: When I mentioned having the heads inspected to Paul...Paul agreed and spoke to the shop!
Old 07-15-2019, 01:18 PM
If you don't want my comments I suggest you lay out all the details, not the one sided comments. Always 2 sides to the story, I only presented part of the other side so people can make an honest interpretation as to what's going on here. We don't want to lead an entire forum in one direction or otherwise this entire thread is useless to everyone.
Look at is as constructive, not negative. We all understand your frustration but pointing fingers will get you no where.
As far as solving the problem, I'll suggest exactly what I suggested very early on, which ended up being the issue the first time, however no one caught it. Too bad. That noise isn't necessarily a concerning noise like bottom end and I've heard it before in many engines. Usually it's a result of too much timing added with initial and/or vacuum thrown in the mix, which obviously is what was happening the first time with the worn distributor bushing jacking the timing all over the place which is why Paul found the moly knocked off the rings (ie:detonation) I believe Mister Pontiac's comments are in line with what I would do. Knowing Paul and knowing the entire story here, I'm 100% confident there was nothing missed in that engine that had anything to do with Paul or Jeff and the underlying issue is something going on after the engine is installed in the car. It's unfortunate you don't have the skill or knowledge to diagnose but I believe if someone that knows what they are doing goes over everything with a fine tooth comb you'll find the cause.
Old 07-15-2019, 10:20 PM
promptcritical's Avatar
promptcritical promptcritical is offline
Formulajones,
What was wrong with the heads that were built?
Old 07-16-2019, 12:02 PM
Va68goat's Avatar
dataway,
The only video I have seen was taken from the booth
Closed Thread
