#621
Old 06-08-2019, 11:54 AM
Default Good For Him!!!
Originally Posted by Va68goat View Post
Paul says the oil filter was free of debris and looked good.
Anyone that says "you can't teach an old dog new tricks" would be wrong on this one.
I'd be willing to bet Koerner Racing Engines is doing this on every engine they build now.
Hard lesson to learn over a $10 oil filter. Especially when ten bucks could be added to the cost of a build. And for what it cost to build these....Customers wouldn't give a second thought to ten extra dollars.
Good for Joe
Good for Paul
And good for Koerner Racing for doing what's right.
Clay
Clay
  #622
Old 06-08-2019, 05:42 PM
gtofreek's Avatar
gtofreek gtofreek is offline
$10 oil filter has nothing to do with this. A full flow filter simply cannot filter fine enough to catch everything. If it did, the engine would starve for oil. Also, we always cut open the oil filter after any engine dyno session.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
  #623
Old 06-09-2019, 12:17 PM
There is nothing on Paul or Jeff here. If you knew these guys on a personal level, talk to them face to face, and visit the shop where they take pride in their work, and see some of the high end stuff they build that make HP, then half the people here wouldn't be saying the things they are.
And for those that don't know, Paul and Jeff build a lot of Nascar South West Tour series engines as well as quite a few engines for people that compete NHRA divisional races, competed in the EMC, and Jeff is a master with Holleys building many of them for Nascar Cup teams before they went fuel injection. So they know a thing or two about making some HP.
  #624
Old 06-09-2019, 12:43 PM
Va68goat's Avatar
Va68goat Va68goat is offline
All I want is the motor that I've been waiting. It's been over 2 years.
  #625
Old 06-09-2019, 03:19 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Remind me what heads / cam?
  #626
Old 06-09-2019, 04:08 PM
Va68goat's Avatar
ponjohn,
Here is what I have!
ID:	513818   Click image for larger version
Name:	Build sheet1.jpg
  #627
Old 06-10-2019, 12:27 AM
meangene meangene is offline
Default pump/ shaft
30 year ago i had almost the same issue , turn my oil pump shaft into a pretzel after closer inspect found out the lint from the red service rags got between the gear and shaft of the oil pump and seize the shaft on the pump and no i did not leave a rag in the motor, it was lint and now i only use paper towel to assemble.
  #628
Old 06-18-2019, 02:41 PM
Va68goat's Avatar
Default Update
The motor should be here before the weekend!! Next update will be the motor running!!!!
  #629
Old 06-18-2019, 06:57 PM
cnc's Avatar
cnc cnc is offline
Nice ....video video video......
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
  #630
Old 06-18-2019, 06:58 PM
cnc's Avatar
cnc cnc is offline
Nice ....Road art ........video video video......
  #631
Old 06-18-2019, 07:44 PM
promptcritical's Avatar
promptcritical promptcritical is offline
Sweet!
  #632
Old 06-18-2019, 08:16 PM
64speed's Avatar
64speed 64speed is offline
Originally Posted by gata79 View Post
Who’d you get to build your engine 64speed? Lynch’s machine shop in Greenville builds a lot of Pontiacs.
To be honest I called Lynches and I know they race Pontiacs but I didn’t get a warm fuzzy. Wayne Sless in Greenwood builds all the engines for the Southeast Gassers Association and his attention to detail is bar none. He built two 421s for a friend of mine and I knew he was my man. Look up Caster1 build thread on here and you can see Wayne’s work
  #633
Old 06-23-2019, 07:29 PM
Va68goat's Avatar
Default Update
My motor is back home and hopefully we'll get to install it soon. Here are the dyno sheets from the first time it was dyno'd and the most recent dyno numbers. This car should be a handful! Sorry about the pictures not being in the correct order. I wasn't too sure how to do that. The 1st two pictures are the most recent dyno numbers!
Name:	2nd dyno page 2.jpg
ID:	514693   Click image for larger version
Name:	2nd dyno page 1.jpg
ID:	514694   Click image for larger version
Name:	1st dyno page 2.jpg
ID:	514695   Click image for larger version
Name:	1st dyno page 1.jpg
  #634
Old 06-23-2019, 09:34 PM
Va68goat's Avatar
1st dyno was Sept of 2017 and the 2nd dyno was June of 2019. I believe the 1st dyno was with headers and the 2nd dyno was with the Ram Air manifolds.
  #635
Old 06-24-2019, 11:09 AM
Va68goat's Avatar
Default Question
Someone asked me a question that I really don't know the answer to. I'm hoping someone can give me an answer. Can someone explain the oil temperature differences in the first dyno pull to the 2nd dyno pull? Is this normal? I really don't know how to even read this dyno sheet at all.
  #636
Old 06-24-2019, 11:14 AM
And it made more power the 2nd time because I believe this time around it had Jeff's carburetor on it
  #637
Old 06-24-2019, 11:26 AM
Va68goat's Avatar
Hey Formulajones,
If you look at the descriptions of the carbs at the top of sheets, both of the dyno sheets are pulls with the Jeff Koerner carburetor.
  #638
Old 06-24-2019, 11:27 AM
My understanding is that Jeff and Paul were still working on your carb at that time. I may have misunderstood him but when I look at those sheets it confirms that. 1st test was an 850 brawler deal that I think was your carb. 2nd test says it's the Jeffy carb which is one of Jeff's special carbs that he builds specifically for a particular combo.
  #639
Old 06-24-2019, 11:38 AM
Va68goat's Avatar
Formulajones,
I don't have a dyno sheet that indicates the 870 Street Avenger that I originally had. I was told that the dyno guy puts nicknames for Jeff's carburetors (850 Brawler). The first dyno had a Koerner carburetor ("Jeffy") on it but it was one that was for another car. The 2nd dyno is the "850 Brawler". The carburetor that was used on the first dyno is posted on this thread earlier.
  #640
Old 06-24-2019, 11:49 AM
So in a nutshell, from what I understand, in the last dyno session, they were able to use the carb that Jeff built specifically for your combo.
Closed Thread
