Old 07-03-2019, 09:34 AM
74gto's Avatar
74gto 74gto is offline
Default Requirements for racing Street class Tri-power Nationals
Can someone direct me to a website that has the rules for street class at Norwalk? The only thing listed in the official website for street class is DOT tires and closed exhaust. I have GTO George's old car, which has a cage. I guess I specifically need to know what rating my helmet needs to be (Date and Snell) and does cage need padding in the driver's area?? I have run this car before at this event, but has been ten years. Also my five point harness is more than two years old, will that matter in street class? Any help appreciated to see if I can make it.
74 GTO 406 T400
74 Firebird 350 4-speed
68 GTO Convertible 400 T400
76 GP LJ 400 4BBL T400
78 Chevy 1/2 Ton Truck
Oh yea I love my wife very much
For some reason it got erased when I put it here last time!!!!!! hmmmmmmmm
Old 07-03-2019, 10:07 AM
Old Goat Racer's Avatar
How quick is the car, ET ?
Everybody knows somthin.
Nobody knows everything !
Old 07-03-2019, 10:24 AM
Elarson's Avatar
Elarson Elarson is offline
Cage needs padding anywhere that helmet can contact.
Helmet can be SFI or Snell rated, to the 2010 or 2015 spec. 2005 helmets or earlier are not allowed.
Aftermarket belts must be within 2 year time limit.
Eric
Old 07-03-2019, 10:49 AM
Its best to get an NHRA Rule Book and follow it as that is what Norwalk does.
Old 07-03-2019, 01:15 PM
firechickenman's Avatar
firechickenman firechickenman is offline
Make sure your neutral safety switch and battery disconnect switch work (if applicable)
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/[email protected]/[email protected]
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69 - Quickest Pontiac
2022 - 10.13 @ 133.07
2025 - [email protected] - 2nd place SRBBNA
Old 07-03-2019, 03:17 PM
Rob B's Avatar
Rob B Rob B is offline
Everything mentioned already WILL be checked during tech at Norwalk and you WILL NOT be allowed to run until any issues are fixed. Many guys last year failed tech and were not allowed to run with inoperable Neutral safety switches. If the car has a cage, it need the correct padding rather it runs 9.0's or 15.0's.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 07-03-2019, 08:29 PM
Mike Kasparian,Sr.'s Avatar
Mike Kasparian,Sr. Mike Kasparian,Sr. is offline
NHRA rulebook states no driveshaft loop needed when running street tires and slower than 11 .49 . Do they consider MT SS and MT Street R street tires ? They are dot approved according to MT . Using a strange driveshaft , don't want to drill any holes in floor of street car .
505 CID, 3560 lbs,Tiger heads, NA.
[email protected] mph, 1.29 60', stock suspension
Old 07-03-2019, 09:54 PM
GTOGEORGE's Avatar
The car use to be legal got run in the 10.80's at one time.
GTO George
Old 07-04-2019, 10:41 AM
At 10.99 you need a tranny shield. I doubt if they will check, let alone how old it is !
How many racers don't have one ??
And don't forget the locking dipstick.
Old 07-04-2019, 11:49 AM
Locking dip stick Norwalk will not bust you for.
No tranny blanket, they will.
Old 07-09-2019, 04:40 PM
AG's Avatar
AG AG is offline
My track checks for tranny blanket
Old 07-09-2019, 05:01 PM
GTOGEORGE's Avatar
Guys I think its a 13 - 12 sec. car now!
GTO George
Old 07-10-2019, 09:24 AM
74gto's Avatar
GTO George
Yes George, it's a 12-13 second car now. Sure I'd like to get it faster. But after a divorce and raising school age kids it's not happening. It still has a driveshaft loop, fuel cell in the trunk, ect. Car has sat for three years, I saved it in the divorce. Just getting it back going. Doesn't look like I'll make Tri Power nationals this year. Thanks everyone for your help. just happy to still have the car right now!
74 GTO 406 T400
Old 07-10-2019, 10:17 AM
GTOGEORGE's Avatar
You wanna sell it? I might want a cruising car when retire from racing!
GTO George
Old 07-10-2019, 10:31 AM
GTO George
Old 07-11-2019, 11:17 AM
A few years ago "MR. Tech" at Norwalk couldn't find anything wrong with my 10 sec. car.
So he suggested I put a clamp on my gas line to the firewall.
I told him I'd look into that.
Sometimes they "nitpick".
Old 07-20-2019, 08:17 AM
wd45gto's Avatar
wd45gto wd45gto is offline
should i have a neutral safety switch with a stick shift car ?
64 tempest wagon 421 gasser
Old 07-20-2019, 08:56 AM
Yes.
Put a switch on the clutch pedal.
(like a brake switch setup)
Old 07-11-2019, 06:13 PM
When was the last time the "GOLDEN GREEK" won first round ?
Granted he can drive the car down the track. .
Reaction time ?
Deep pockets/sponser go a long waaaay
OR, back to topic !
Old 07-20-2019, 11:12 AM
younggto younggto is offline
Correct John; nothing in the NHRA manual says about having one with a stick and I’ve passed tech at Norwalk without one. It makes perfect sense to have one but not required.
