#61
Old 06-03-2019, 03:38 PM
unruhjonny's Avatar
Is the car cleaned up?
I'd love to see some dirt-free pictures.
Inside and outside!!
This is a cool & unusual car!
1970 Formula 400
  #62
Old 06-04-2019, 08:21 PM
77 Canamman's Avatar
I did wash it with Palmolive detergent. It had several areas where motor oil was spilled on the finish. The paint was slightly oxidized prior to its 32 year storage. I am in the process of cleaning up the paint, and what areas I have polished, the finish looked good. Pics to follow.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
  #63
Old 06-04-2019, 11:40 PM
unruhjonny's Avatar
I look forward to it!
1970 Formula 400
  #64
Old 06-05-2019, 11:46 AM
bird72's Avatar
bird72 bird72 is offline
Love this car & happy you are saving! Will be a stunner & most important DIFFERENT. I had a full tilt, cammed 455, headers, 2800 stall, in a column shift 72 Formula. I will attest that power shifting a column shift is possible. Just don't zoom past into N. And definitely don't spaz into R
72 Bird
  #65
Old 06-12-2019, 04:05 AM
Thumbs up
I was able to change out the PCV, spark plugs, wires, cap, rotor, and add the distributor RF shielding. Before this however, the entire car was treated to a good, thorough pressure wash of the engine compartment, and undercarriage, which removed a few pounds of dirt and cobwebs. After all of the work, the car fired right up and ran absolutely perfect. I added a couple of pints of ATF, and the TH400 transmission finally decided to function. The car moved about 20 feet on it's own for the first time in 30 years. Since the brakes are not working at this time, I did not road test the car. Progress is being made!
ID:	513978   Click image for larger version
  #66
Old 06-12-2019, 07:04 AM
SD455DJ SD455DJ is offline
77 Canamman - Nice work...on a nice Formula! I really like that combo and the way it was optioned. Many Firebirds were made with the column shift as many dealers forgot, or didn't realize ordering the console was the only way to get the floor shifter. We have a '73 455RA Formula (4-spd) that comes to the Pure Stock Drags that runs 14 flat at 103 mph with 3.42 gears and weighs 3700 lbs. These cars can run with the big dogs with a little tuning and driving skill.
I'm looking forward to watching your progress!
Dennis
  #67
Old 06-15-2019, 09:16 AM
Some photos of the car somewhat cleaned up.
Sent from my XT1650 using Tapatalk
  #68
Old 06-15-2019, 10:00 AM
unruhjonny's Avatar
wow!!!
1970 Formula 400
  #69
Old 06-16-2019, 09:47 AM
Pepi's Avatar
Pepi Pepi is offline
Cool car, can't wait to follow the progress!!
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #70
Old 06-17-2019, 12:35 PM
That Formula is looking better all the time. Can't wait for more pictures 77 CAM!
Dennis
  #71
Old 06-25-2019, 10:37 PM
I was able to begin the brake rebuilding. New AC Delco rotors and pads along with remanned calipers and new hardware were successful. I was able to drive the car around the block. Since the tires are dry rotted, I kept the speed under 30. It lights up the old BFGs with only a blip of the throttle.
  #72
Old 06-26-2019, 07:44 PM
30TYBIRD 30TYBIRD is offline
Default 1973 Formula 455 also
Following this because I am about ready to start this process on my original 73 Formula 455 with Ram air with 27,000 miles to get it road worthy. This was an Akron OH car that sat for years with some poor storage. It has some minor low quarter and tail panel rust, but none in floors or trunk. I need to start a thread like yours and would like to compare some thoughts with you sometime.
Thanks Rick Legg
  #73
Old 06-27-2019, 07:22 AM
Will do, Rick.
  #74
Old 06-27-2019, 12:20 PM
J GLASGO's Avatar
J GLASGO J GLASGO is offline
Akron?? How did I not own this? Details!
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of!
  #75
Old 06-28-2019, 04:09 AM
Lightbulb
http://forums.maxperformanceinc.com/...d.php?t=783916
https://www.ebay.com/itm/1973-Pontia...orig_cvip=true
  #76
Old 07-10-2019, 08:31 AM
Smile
I rebuilt the rear drum brakes. The bonded friction surfaces fell off the shoes due to old age. I had the original smooth faced drums turned to remove some light surface rust on the friction surface. However, this was no easy task. Only one older shop in town still performs this service. This is another casuality to this disposable society. I blasted the exterior of them and then shot them in high heat black paint. All of the rear drum parts were on the shelves at the local CarQuest-even the drums if the originals were not salvagable. I drove it around town for a bit. The 455 runs well, and the transmission works fine. The brakes now stop the car well after the rebuild.
ID:	515550   Click image for larger version
ID:	515551   Click image for larger version
  #77
Old 07-10-2019, 12:56 PM
77 Canamman - It should be good enough to drive to this years TA Nationals in Dayton. I'm sure it would be a hit with all the attendees and spectators. you are making great progress on the Formy and we are looking forward to more pictures form you.
Dennis
  #78
Old 07-10-2019, 01:13 PM
Judge273's Avatar
Judge273 Judge273 is offline
I feel lucky! My local auto parts store did my drums.
Looks awesome! Love the progress and originality uncovered! Well documented fun...
Mike/Illinois
  #79
Old 07-10-2019, 01:36 PM
unruhjonny's Avatar
On the subject of drums, I foolishly tossed my original unfinned drums in the late 90's;
Is there a source for correct replacement unfinned drums?
(even ones which have been relined?)
EDIT:
I have understood that when buying relined drums, it's a crap-shoot if you get finned or unfinned.
Maybe I'm mistaken?
1970 Formula 400
  #80
Old 07-10-2019, 01:54 PM
Red face
This car desperately needs new rubber before any speeds of 30 or over are attained. The tires I want are the reproduction Firestone Wide Oval F60-15. It will be a couple of months before I will have the spare cabbage for them at $1250 for 4 before mounting and balancing.
