#1641
On the shock issue -- My turbo gar had Strange -- and as it got faster we had issues -- long story short -- swapped to custom configured Penske and Bazinga -- fixed ir
#1642
Damn silly turbo cars!
#1643
lol yea they are a beast of there own ---- btw that popping noise you hear them make at the starting line is because some applications pull A LOT of timing to get the thing spooled up -- more so on a stick car but still need some on an automatic -- live long and prosper
#1644
OUCH!
#1645
Oh no
Gonna have it back together for Norwalk? |
#1646
![]() 2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
#1647
That sucks big time. Could have been much worse though
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
#1648
It's going back together, Kingsley Machine turned the head around in under a week, Don from DCI Motorsports had guides, and other needed valve train parts delivered in 2 days. Joe Bass supplied a set of T&D steel rockers when T&D said it would take 3-4 weeks to get a few replacements. T&D then ended up delivering the replacements and a few spares in under a week.
We're looking much better right now.
#1649
Did you find the root cause?
#1650
I'd say currently inconclusive.
Machine shop was leaning towards valve failure. Victory performance is interested in taking a look at the valve train.
#1651
Is the top of the piston beat up? The first pick it looks like something was bouncing around and hitting the valve... the other one well...it was ****ed and folded in half...
#1652
Could have been much worse, if the valve head hadn't "hid" in the port. When I had an intake valve separate like that (my very first blown iron Pontiac) the valve head apparently didn't try to "hide"- broke a whole corner off the block!
I sure hope you make it to Norwalk. I've been waiting to see it run.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
#1653
How does the keeper, retainer, spring, rocker arm, pushrod, lifter and cam lobe look? Victory valves are pretty high quality, i wouldn't think the head would pop off like that unless it was the wrong valve for the application. I would definitely look things over closely to insure something else didn't cause it so it won't happen again.
#1654
Lucky the valve head didn't dance around the chamber/cylinder.
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
#1655
The Raven just fired back up, too late to pull it outside. We'll heat cycle it tomorrow and re-torque head, re-adjust valve and check everything over.
#1656
What valves are they ? Are they made from inconel?
Good luck with the fix....
My Half AN Injun..... |
#1657
Wow- quick repairs! Glad to hear it fired up okay. Hope you make it to Norwalk.
#1658
The "RAVEN" will see you all in Norwalk.
#1659
https://www.youtube.com/watch?v=dd1MMkdUW6c my three best guys working on it
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
#1660
Did you replace all of the valves?
