Old 07-31-2019, 05:48 PM
STEELCITYFIREBIRD's Avatar
It would be weird if it ended up being something like the valley pan flexing under fluctuating vacuum signal ... like popping the bottom of a tin can back and forth.
I could only see that happening if there is no or inadequate source of air in to motor.
Just pull PCV valve and cover with your thumb. No noise reduction or smoother running... move along.
Compression tester is nothing more than an air pressure gauge with a check valve inline. (motor is an air pump your testing). A quick check with your shop air from a rubber tip blow gun will verify your gauge and integrity of the hose and check valve against shop compressor line regulator gauge psi output . The only thing you can't check is how well it will seal to the spark plug hole.(without some fabrication).
Any info/pictures on which crank pin/s the problem occurred on or pics of crank and damaged/replaced rods/parts?
Take all the spark plugs out when doing compression test on an entire engine!
Old 08-15-2019, 06:46 PM
Va68goat's Avatar
Va68goat Va68goat is offline
STEELCITYFIREBIRD,
I'm hoping for that.
Steve C.,
Collusion or conclusion? Hahaha
Old 08-15-2019, 07:14 PM
Steve C. Steve C. is offline
Carnac suggests no secret cooperation or conspiracy, especially in order to cheat or deceive.
Old information here:
Closed Thread
