Is there any chance you have any better pics of the exhaust flanges? It's hard to see but looks like the center ports were sealed up well but #2 and #8 not so much.
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55 '72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80 |
I see one of the intake valves is especially clean. A lot cleaner then the rest, while it doesn't explain the nock is that cylinder even firing?
Let's make welfare as hard to get as Veterans benefits! |
I still question the timing during much of the running, I doubt it was 'right'. That also would explain the uneven burn across the cyls. Also, the idle mix screws were all over the place. All those pics are of the passenger side head, fyi. .
I don't think you can put much stock in what the piston crowns and chambers look like. This is a high performance engine that's done nothing but idle for 2 years. It's had all 12 disciples, every street preacher and the ghost of Wolfman Jack laying on of hands and twisting the knobs trying to exorcise the demon.
It's going to show carbon build up. But it is good to notice it is happening, as continued prolonged idling while d!cking with it is going to carbon the engine up enough to cause other issues. How deep a dive is this shop going to do? Out and apart?
I could explain all this to the girl at the parts store, but she'd probably call the asylum. White '67 LeMans 407/TH350/Ford 3.89... RIP Red '67 LeMans. 407/TH400/Ford 3.25 Last edited by chiphead; 08-19-2019 at 09:20 AM. |
NeighborsComplaint,
I have a felling that the motor is going to come out. At this point, I just don't know by whom. chiphead, A few guys have worked on the motor. None of them did anything that wasn't instructed by Paul or approved by Paul. The guys that have worked on the motor are all experienced car guys (25+ years of experience). I don't know how far their guy is going with the motor. He's doing some more diagnosing that Paul has suggested. ponjohn, Thats a consideration. The machine shop that inspected the heads has a dyno and I believe they have a test stand. That may be an option for the guy that Paul and Jeff have looking at my motor. |
I honestly can't see what removing the engine mounts and setting the engine on wood would help?
either do I, except cause more damage.
ponchjoe,
I've heard of CVM. They're about 2 1/2 hours away. At this point I'm not getting in the way of Paul and the guy they found to look at this motor. I want to avoid sending this motor back to Arizona if at all possible. chiphead, I agree. Since we now have a third party looking over this motor, I think it would be a good idea to continue to let him see this through, if he is willing. I really don't want to see this motor leave Virginia. As for the pistons, I don't know what it means to coat a piston but thats not what I paid for. I've spent a ton of money on parts that were suggested that I obviously didn't need and the knocking noise has never left. STEELCITYFIREBIRD, We'll get the idle down where it needs to be. I believe Paul said 900 rpm would be good for idle. Though I want to get to a point where I can enjoy this motor, I'm patient enough to let this play out. |
The challenge with something like piston slap is that it can be acceptable from a technical standpoint. A 2618 forged piston with .005" skirt clearance is a common clearance, and it may slap depending on piston geometry. A 4032 piston with .005" has a good chance of slapping, even when warmed up. That's why I asked what the piston was made out of. We know you're at about .005" skirt to wall now. My 400 motor slapped at .0055" and I ran the snot out of it for years on the street, incl making several nitrous passes at the track. My machinist warned me it might slap, and it did. The early LS motors slapped before they went to coated pistons and they ran 100K like that. Point being is if you have piston slap with no other issues, some of that is normal with a heavily modified engine. Excessive piston slap is when the piston has enough clearance to rock A LOT in the bore as it goes over TDC and BDC. That's what causes the slap noise, as the skirt to wall clearance transitions from one side of the piston to the other as the piston changes direction in the cylinder. This will cause accelerated piston ring wear and upset ring sealing. In severe cases, piston rock can damage the skirt and require replacing the pistons. So checking the skirt clearances should definitely be done if the engine comes apart.
I have heard you guys talking about piston slap and thought it was the piston coming too far up. After reading Chip I learned something new.
The challenge with something like piston slap is that it can be acceptable from a technical standpoint. A 2618 forged piston with .005" skirt clearance is a common clearance, and it may slap depending on piston geometry. A 4032 piston with .005" has a good chance of slapping, even when warmed up. That's why I asked what the piston was made out of. We know you're at about .005" skirt to wall now. Thanks Chip.
What's the difference between that and an engine run stand? |
Grasping at Straws meaning: To be grasping at straws means to be willing to do, say, or believe anything that offers even the slightest hope in a desperate situation, even though there is almost no chance Running race fuel through it ain't helping Clay |
, Its possible that the result of the selected engine tech not finding anything external to the engine to explain the knock will result in the tech pulling the engine followed by a free ride of the engine back to the Koerner Racing to be made right...![]() One can only hope
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
If the noise is more pronounced or audible at lower RPM, and as as you stated...
Get the idle down lower, adjust the idle mixture/speed in now that the vacuum leak is? repaired. Clean or replace spark plugs if needed to smooth out idle. I agree Joe, experienced sets of ears hone in on problem area pretty quickly.
| Closed Thread |
