#1701
Old 09-01-2019, 08:17 AM
67'7F6'Bird's Avatar
Right Lane
  #1702
Old 09-01-2019, 08:30 AM
Stan Weiss's Avatar
Congratulations. Looks like you added a little more power, but it also looks like you are starting to get a handle on the 60 foot times also.
Stan
Pontiac Pump Gas List
  #1703
Old 09-01-2019, 08:31 AM
Stan Weiss's Avatar
Originally Posted by 67'7F6'Bird View Post
Right Lane
So what is happening with your car?
Stan
  #1704
Old 09-01-2019, 08:37 AM
johnta1 johnta1 is online now
Are you leaving off-idle?
The 60 foot looks slow but it's coming on stronger later.
Probably making boost gradually?
I would say it's got a lot more in it?
  #1705
Old 09-01-2019, 09:12 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Stan
Hey Stan,
We're getting boost building on the t-brake under control, finally leaving at above 6lb of boost. Increasing overall boost to ~28lb.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1706
Old 09-01-2019, 09:17 AM
RAIV-Z's Avatar
The 1.2x 60's will start to get better, getting used to the additional launch boost will take a few more passes. This was the first one. It's was a bit of a change going from 6lb to 10.7lb.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1707
Old 09-01-2019, 12:36 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Not a bad day at the track today. Still turning it up.
I'd love to have that time slip, since I'm certified to only 7.50 with my mild steel chassis.
Congratulations! Don't stop there.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
  #1708
Old 09-01-2019, 01:13 PM
cgeise's Avatar
cgeise cgeise is offline
so what boost controller are you using ???
  #1709
Old 09-01-2019, 02:52 PM
RAIV-Z's Avatar
It's part of the Holley Dominator EFI ECU.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1710
Old 09-02-2019, 09:36 AM
ponjohn's Avatar
ponjohn ponjohn is offline
What "should" the 60ft be?
  #1711
Old 09-02-2019, 10:35 AM
GTOGEORGE's Avatar
I’m thinking with the boost he’s running now he’s pretty darn close for a turbo car!
GTO George
  #1712
Old 09-02-2019, 10:42 AM
Most ET's I have seen around that time is usally 1.0x seconds?
(mine in my slow dragster is 1.09-1.15)
I suppose the turbos may be 'soft' on launch, but don't see why it should be.
The guys that are hampered by small tires would probably have slower 60' times.
  #1713
Old 09-02-2019, 11:41 AM
opeliac opeliac is offline
It’s a learning curve for sure, and it looks like he’s going in the right direction.
As for small tires having slow 60’ times. Most decent 275 tired cars will go in the 1.10 range on decent tracks. A good one on a radial prepped track will go low 1.00s.
  #1714
Old 09-02-2019, 02:00 PM
Thanks for the small tire info.
My sentence should have been 'could probably' and not 'would probably'.
I have no info on their et slips to check with.
And I agree the learning curve is going the right way.
Will be lots faster I believe.
  #1715
Old 09-02-2019, 03:23 PM
RAIV-Z's Avatar
We expect the 60's to be in the low 1.1x range or better. Keep in mind that we have not touched any chassis settings yet, only tire pressure.
1.215 60 foot.
https://www.youtube.com/watch?v=uplki1u8Gdk
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1716
Old 09-02-2019, 04:59 PM
Looked good!
What's the rev limiter RPM on while on starting line?
  #1717
Old 09-02-2019, 07:12 PM
RAIV-Z's Avatar
Looked good!
Spark Only
On RPM 4800
Off RPM 4770
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1718
Old 09-04-2019, 11:50 AM
cgeise's Avatar
ok Im not sure how that one sets up but on the one I used it worked best by ramping up in small quick steps --all in by a second or less
  #1719
Old 09-04-2019, 08:25 PM
RAIV-Z's Avatar
Were you adding/removing fuel and/or Timing?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1720
Old 09-09-2019, 10:30 PM
cgeise's Avatar
the boost controller was adding pressure to the back side of the waist gate in small increasing amounts very quickly -- the fuel pressure regulator added fuel based on boost pressure ie boost referenced and if I remember right timing was at about 25 degrees over 12-15 lb boost . Boost controller setup was 12lb springs in the waste gates and then every lb of c02 on the back side of the gate increased boost by aprox a lb -- data recorder will tell you exactly how much.
