Old 10-17-2019, 08:19 PM
footjoy's Avatar
footjoy footjoy is offline
Default Had a chance to put my car on a dyno today
Guess what Horse power this put out?
Build
400 .060
Flat top with one valve relief
Crower 60240 cam
#15 small valve heads 87cc
Performer Intake
HEI 14 initial 35 all in at 3000
Quick fuel 735
AFR 12.8
Old 10-17-2019, 08:25 PM
Mustang or Dyno Jet?
4 speed or auto?
Old 10-17-2019, 08:27 PM
shaker455's Avatar
Old 10-17-2019, 08:29 PM
footjoy's Avatar
4 speed or auto?
DYNO
Auto
Old 10-17-2019, 08:31 PM
Old 10-17-2019, 08:47 PM
footjoy's Avatar
217 peak horse power
Old 10-17-2019, 08:50 PM
footjoy's Avatar
I didn't think you could build a pontiac with that low of horse power. I was hoping for 300.
Something definitely went wrong.
Greg
Old 10-17-2019, 09:46 PM
694.1 694.1 is offline
Is it fun to drive now? Just wait until you get it dialed in
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 10-17-2019, 09:56 PM
4dblnkldude's Avatar
Lucky if above 250 to the wheels.
Old 10-17-2019, 10:22 PM
moontower69's Avatar
moontower69 moontower69 is offline
Default I had that combo (255-260 HP at wheels)
Crower 60240 is a smooth running cam but hard to dial in. I had to advance that cam 2 times to get any performance out of mine on a 389 (first 4 degrees and then 6 degrees advanced was just right).
It's strange because the cam supposedly comes with 4 degrees dialed in but if you go dot to dot it will be a dog. Must degree it on a wheel to verify.
You'll get 255-260 HP at the wheels with that cam, all done making power at 4800-5000 (but revs higher no problem). It makes about 325 HP at the flywheel x 20% loss or about 260....your compression ratio looks to be about 8.5:1 which is fine with that cam (and will run w/ no detonation worries on 87 or 89 all day long). I had 90cc small valve #11 heads and made decent power. Its a driver cam.
1974 Lemans Sportecoupe GT (daily driver)
.030 over 354, #47 heads (84cc), Lunati voodoo 700 camshaft (207/213 @ .050), logs, 2.5 duals, X-pipe and Dynomax super turbo mufflers, 3.08 rear
Old 10-17-2019, 10:42 PM
footjoy's Avatar
I think this cam is more sophisticated than I know how to work with.
When I was getting parts for this build I originally bought a summit 2801.
Does it have to be degreed? would it work with my set up?
Old 10-17-2019, 10:55 PM
Stan Weiss's Avatar
Build
400 .060
Crower 60240 cam
Performer Intake
Quick fuel 735
AFR 12.8
What does your CR calculate to? If you don't have all of the needed data for the CR then what is your Cranking Compression?
Stan
Pontiac Pump Gas List
Old 10-17-2019, 10:59 PM
footjoy's Avatar
Stan
Around 8.75-8.80:1 All cylinders were 156-162 with no leak down.
Old 10-17-2019, 11:04 PM
footjoy's Avatar
Build
400 .060
Crower 60240 cam
Performer Intake
Quick fuel 735
AFR 12.8
I made a mistake it is bored .040
And the compression is about 8.8:1
Old 10-18-2019, 06:06 AM
You need to mill those heads to get the comp up to 9.5 to 9.7 and that will bring the cranking compression to the needed 180 range that the 3.750" stroke of 350, 389 and 400 motors need so to speak.
This means you need a 10 cc reduction in chamber volume, so milling the heads .060" on the deck and the Intake flange will do the trick.
Note that milling this much off the heads means that you will have use only a bead of gasket maker on the valley pan and you might also need to trim some meat off of the bottom of the Intake Manifold to get things bolted up and sealed , but the power gain will be worth your time , money and effort!
Be sure that once the milling is done you lay a head gasket on the head and roll/ polish over any sharp edges of the deck that now stick out passed the fire ring of the head gasket.
Old 10-18-2019, 07:07 AM
Greg
Not that easy to hit 300 at the wheels with a 400. But you still haven't mentioned what you made. Did I miss it?
I wouldn't say anything went wrong given the specs you provided. A few years ago a bunch of Pontiacs hit the chassis dyno. Including myself with my stock 400 RAIII, auto. I made 301hp while most of the other 400 cars were in the 270-280 range, and some of them had aftermarket cams and what not. A few of the 455's barely hit 320-330hp. But I've had a lot of years racing and tuning on the car. That day I was running 13.60's at 102 at the track at a 3900 lbs. race weight, which coincides well with the RWHP numbers I put up.
Edit: Okay I see it now. 217 is lower than I would have expected for that combo.
Old 10-18-2019, 08:10 AM
footjoy's Avatar
When people talk about a good tune which my car needs, how much horsepower can be gained by a good tune?
Old 10-18-2019, 08:43 AM
If your air to fuel ratio is good through out the motors rev range which it seems to be from your posting of a average 12.8 ratio then the only thing left in terms of getting your motors needs peaked out is to make some dyno pulls / run's while putting in timing changes and to try out different octane fuels.
One thing to watch out for if you go playing with different octane fuels is that the air to fuel ratio can need to be changed from what it is now .
With your motors current compression ratio I can't see why anything more then 87 octane is needed to keep the motor alive , and don't forget that running a octane level higher then the motor needs only cuts into the power that a motor makes as the RPM goes up!
For a street motor I am not sure if this is a can of worms you want to open because at most your looking at a gain of about 8 hp, and your looking for a missing 30 hp or more, so stick with just trying out some different total timing changes.
Old 10-18-2019, 09:47 AM
shaker455's Avatar
Not a bad number for a conservative build.
I'm sure some in depth tuning will make it pretty snappy.
Old 10-18-2019, 10:07 AM
Lee's Avatar
Lee Lee is offline
That depends on how far it is off to begin with. By tweaking timing and jetting, I rarely find LESS than 10rwhp on cars I've tuned. 20-30 is pretty common. I've found over 60 a few times.
Mild cam, mild compression, small valves,.... based upon other Pontiacs I've dyno tested, you may have another 15 or so HP. Nearly every stock headed Pontiac I've seen on a chassis dyno has put less than 300hp to the wheels.
What is your torque, though? People focusing on HP with Pontiacs running unported heads, they are studying the wrong end of the dog.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
