#101
Old 11-25-2019, 11:24 AM
1965gp 1965gp is offline
Looks like this project is really coming along! Can’t wait to see the metal work
  #102
Old 11-25-2019, 01:08 PM
ZeGermanHam's Avatar
There will certainly be ample metal work, so make sure you bring extra popcorn to the show!
1998 BMW 328is (track rat)
  #103
Old 11-30-2019, 11:06 PM
With the body now with the sandblaster, I've been taking a closer look at the frame. I noticed that the trans crossmember is bolted through a hole on the driver side, but just held down (barely, I might add) with a washer on the passenger side. There is not a bolt hole on the passenger side of the crossmember. Is this normal? Seems like it would be bolted on both sides. The trans is a TH400 (i.e., not what the car was born with), so I'm not sure if this is the original crossmember.
  #104
Old 12-01-2019, 12:09 AM
RedDirtRoad RedDirtRoad is offline
You are missing the rubber isolator and the bracket that hold the crossmember in place
  #105
Old 12-01-2019, 10:18 AM
Jeff Hamlin's Avatar
As mentioned, That needs some attention;
Our host carries both the Brackest & the Insulators.
  #106
Old 12-01-2019, 11:08 AM
Thanks for the info, guys! That makes way more sense. Now I've got one more item to file in "stupid things the previous owner did."
  #107
Old 12-01-2019, 10:43 PM
gtospieg gtospieg is offline
The good news is your crossmember does not appear to be rusted on the end where the rubber isolator and bracket would hold it.
  #108
Old 12-02-2019, 12:31 AM
The other side is a bit rusted out. But with that said, I think I'm going to box the frame, and in doing so I will likely trim the crossmember and adapt it so that it bolts onto "shelves" on the side of the boxed frame.
  #109
Old 12-17-2019, 11:35 AM
Got the GTO back from sandblasting yesterday afternoon. On the whole, there were no major surprises, so I'll call it a win. I knew it had rot in a number of the typical areas, but I was pleasantly surprised to learn that the lower cowl, rockers, upper quarter panels, and wheel arches are in very good shape. It'll need a new trunk pan, tail panel, rear lower quarter patches, rear deck, parcel tray, and some work around the base of the A-pillars and lower windshield. Ultimately, not too bad for a Michigan car.
ID:	526931   Click image for larger version
ID:	526932   Click image for larger version
ID:	526933   Click image for larger version
  #110
Old 12-17-2019, 11:39 AM
you are lucky
I am jealous! Haha
  #111
Old 12-17-2019, 12:00 PM
Originally Posted by RedDirtRoad View Post
you are lucky
I am jealous! Haha
It's still going to be a lot of work, but I'm just thankful that it's not any worse than what I was anticipating before sandblasting.
  #112
Old 12-18-2019, 11:39 AM
Now that the GTO is back from blasting, I'm beginning to think about the best approach to fixing various issues. One area that I have a question about is the upper window channel for the rear quarter glass. Has anyone here had to deal with this area on their car? So far I haven't seen replacement pieces available for this spot, but I suppose someone may make them?
  #113
Old 01-07-2020, 01:22 AM
Things are staring to pick up with the GTO now that most of the sheet metal has arrived. The doors are done, and the tail panel, trunk, and rear deck panel came out today.
ID:	528362   Click image for larger version
ID:	528363   Click image for larger version
ID:	528364   Click image for larger version
ID:	528365   Click image for larger version
  #114
Old 01-07-2020, 01:23 AM
A few more photos...
ID:	528367   Click image for larger version
ID:	528368   Click image for larger version
ID:	528369   Click image for larger version
ID:	528370   Click image for larger version
  #115
Old 01-07-2020, 02:32 AM
Major progress! I agree that’s pretty solid for a Michigan car
  #116
Old 01-07-2020, 02:39 AM
Yeah, these west coast guys out here in Seattle think it's a really rusty car, but they don't know what cars are like back in the Midwest and Northeast. It's all relative.
  #117
Old 01-07-2020, 07:29 AM
That’s some nice work
Looking real good so far
Your metal work on the doors are impressive.
Did you mig them or tig weld them?
I have a tig welder but still have not mastered it yet as well as mig welding
  #118
Old 01-07-2020, 10:53 AM
I wish I could take credit for the metal work, but along with paint work, it's something which I'm not doing myself. I'm doing everything else involved with the restoration, however. My metal guy is a true artist and craftsman. I'm always amazed at how quickly and efficiently he comes up with solutions to problems which leave me puzzled and scratching my head.
The doors were mig welded. I believe the tig welder may be used in a few areas of the body where heat management is more of a concern.
  #119
Old 01-07-2020, 08:28 PM
I hear you
I am doing the same as you
I have a metal/body man and I have a painter
I am just disassembling bagging and tagging as well as refinishing all the small parts then I will reassemble it all back
  #120
Old 01-08-2020, 09:22 PM
Question for those of you who have replaced the rear deck panel before... Did you put some kind of pad between the deck panel and the parcel tray structure below? If so, what did you use? Some sort of closed-cell rubber mat?
