Old 12-04-2019, 10:30 PM
ponyakr's Avatar
ponyakr ponyakr is offline
"...Won all my bracket racing cash and trophies with a cast rod 455 running in the 12s for over a decade, the rods weren’t even rebuilt..."
Ditto.
A rev limiter, set on 5500, saved my 455's, many times.
455abody 455abody is offline
The little end of the rod is to small he said he did not want to enlarge it to fit the pin. I got a good buy and some forged H beams so I went in that direction. Should work out all right
Old 12-04-2019, 10:34 PM
tom s tom s is offline
to me its sounds like the inside of the piston where the small end of the rod goes in is too narrow for a factory cast rod,exactly what happened to me.Tom
Old 12-04-2019, 10:39 PM
ponyakr's Avatar
WOW ! I suppose that's the 1st time I ever read of a shop that wouldn't hone a pin hole, to better fit a pin.
Surely they didn't think .001 would reduce the rod strength enuff to cause a failure.
Have to wonder how many Pontiac engines these guys have built.
Old 12-04-2019, 10:50 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Paul,Racetec did mine and the opening was too narrow to use a stock cast rod.That was with a 428 custom piston.Tom
Common deal with Racetec. Have to be sure to let them know if you're using a factory rod and give them the width and height of the balance pad if the rod has one.
Go fast, see Elvis!
Old 12-04-2019, 10:52 PM
PAUL K's Avatar
Same issue you'd have using a cast rod with an SD455 style piston. Narrow the rod end and the problem is solved.
Go fast, see Elvis!
