1973 Valance
Finally getting around to getting my 73 TA on the road again. When I bought it, it had a 72 front bumper on it. I bought a used 73 bumper for it. Working on installing it. My buddy and I have found the lower valance doesn't have provision for mounting support bracket. Valance is metal. I think it's for a earlier years. I believe the nose and valance were replaced from a accident years ago. Should I buy repop 73 one from Ames? Has anyone bought one from them? Thanks for
69 Judge RAIII 4SP 2ND OWNER 63 Catalina 421HO 4sp 66 GTO Conv 4sp 73 Trans Am 455 4sp http://www.sdperformance.com/ Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds. |
I have a '73 Formula, and the original plastic valance has been repaired several times, and it is about hopeless. I too am curious is the Parts Place part that Ames sells is worth the effort.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
Do you have the triangular shaped bracket that bolts to the lower end of middle vertical rad support brace? Might help if you posted a picture... |
The Parts Place plastic replacement valance is the best thing going for the correct look but it will require some fitting.
1972 Trans Am Lucerne Blue /white 4spd 1973 Trans Am 455 4spd, White/Black..Junior Gold POCI 2012 1974 Trans Am SD455 4spd. 29k mile unrestored. Buc Red/white 1948 Lincoln Continental Cabriolet V12. Restored. 1951 Willys Jeepster 6 cyl. 1968 Olds Cutlass W31 Ram Rod. Nocturne Blue, 4spd, stripper 1969 Hurst Olds survivor 1970 Challenger RT Convert . 383 4spd. Plum Crazy/white 1971 Datsun 240Z 1978 Datsun 280Z Black Pearl edition 1983 Jeep CJ7 Renegade 2013 Corvette Gran Sport |
Parts Place repro is not dead on, several years ago compared side by side a PP repro to a low mile original '71-73 piece, took a bunch of pics as well.
So what are the incorrect details, and it is worth the north of $300 price?
The originals were plastic, GM replacements were steel and require different parking lamp fillers.
Did Pontiac initiate a program to replace the plastic lower valance with the steel valance?
Back in the early to mid 1980s, I ran into a Ford guy who had bought a bunch of NOS parts from a small town Pontiac dealership that closed in around 1975. He was planning to go through the parts and sell them on Hemmings but never got around to it. I was able to buy everything he had, which was about four pickup truck loads. Among the inventory were roughly a dozen new 70-72 lower valance panels and a box full of the brackets for the middle support. The dealership wasn't that large, and the number of Firebird valance panels seemed disproportionate to the reest of the parts. My guess is that they were having to replace a bunch of broken valance panels, or Pontiac was replacing them with metal under warranty. Mike |
1. The early same steel one used in '70, and '71's with the multi piece light assembly with a clear lens. ( the first Valence) 2. Around the middle of November of 1971, Pontiac got the bright Idea of using the plastic valence. ( The second valence) This failed before cars even made it to the unfinished car lot. This first plastic Valence had a "Clear" capsule. It used a different front light harness as well, with a bulb socket that twisted in like a tail light, to the clear capsule. 3. Due to breaking of the lower valence, Pontiac had a steel unit built ( The 3rd Valence) that would hold the new Clear capsules, and also the Amber ones introduced in Late Dec of 1971. This is the Valence that was force shipped out based on sales, and many cars got one ( unpainted ) in the trunk with instructions for the dealership to paint and install. What you have are the GM replacements, which some were made up until 1979. These will even work with the early style assemblies, but there is more gap around the metal socket part. These fit against the lower fenders WAY, WAY better than ANY metal replacements out there. Here are the second Two light Capsules. The clear one from my Nov'71 built Firebird, the Amber from my Dec '71 Built Firebird. The Amber continued through all of '73. |
My late 72 has amber lights in a replacement steel valance. It was missing the center bracket, so I knew it was not original. Also had no filler pieces around signals, so it was whammed together. Since not a pedigree rare car, I'll keep functional steel valance over problematic plastic. I fixed the incorrect, missing stuff.
72 Bird |
Stay on topic..what needs to be done to the Ames/Parts Place plastic reproduction part, and is it worth the $300 plus dollars?
I personally do not like the looks of the steel valance, so I really prefer not to go there...
From a distant appearance sake, the PP repro is close. It is, however, injection molded of thinner plastic, esp noticeable where the quarter shapped access holes are near the parking lamps. Several shapes & detail lines also don't exist, on the bottom the rectangular slots evident on an original don't exist. those will be cutout as I modify & reinforce from the backside two of the repro's. My .02, building a bug-smacker/driver or local "showcar", use a metal used or repro valance with parking lamp fillers.
The Following User Says Thank You to 'ol Pinion head For This Useful Post: | ||
Thanks for the explanation, FormulaBruce
I always wondered why only a couple of the valacnes were in boxes, the rest were loose. I suspect the dealer collected them and only installed the metal ones if customers complained. |
The Parts place repop for '73 "plastic" valence has issues at the fender fitment and I have found it to be different from side to side.
I used a heat gun on one to get the capsule in correctly. |
The Following User Says Thank You to Formulabruce For This Useful Post: | ||
The Parts Place valance is the only game in town unless you want to wait and hope you might score an original. I have no first hand experience, but have talked with numerous people that have fitted one or more including Darrell that did my Black Car. My takeaway is that it is a 6 out of 10, but will require a material amount of work to get it flattened out and to get it fitted at the ends. Sort of like fitting the TA wheel flares, a heat gun will be your friend. If you hate the metal replacement and have $1500 to spend for parts and labor get it. It’s the only option for anything other than the metal replacement.
Sent from my iPad using Tapatalk |
i have a metal valance with the amber lights . do you think mine was changed out back in the day |
I have the original off my '73 Formula project, but like many, it needs some repairs. I bought a heat stapler and 3m epoxy to fix it, but its a bit down the list. |
As Bob and OPH have said, the Part's Place valance is as good as you can do unless you come up with an original.
I have several of the originals and have compared to the repop. In addition to what has already been shared, the shape of the large openings are noticeably different and the contours are different. Another obvious difference is the lack of a styling ridge along the top edge and around the openings of the repop. Once you've seen these differences, you can recognize a repop right away.
69 GTO 400, 4-Speed, Matador Red 69 SCJ Mach 1 Mustang, 4-Speed, Drag Pack 72 Trans Am, 455HO, 4-Speed, Lucerne Blue 73 Trans Am, SD-455, 4-Speed, Brewster Green 73 Formula, 455, 4-Speed, Ascot Silver 73 Formula, 455, Navaho Orange Survivor |
The Following User Says Thank You to Red Goat For This Useful Post: | ||
Could someone post a pic of the centre support your referring to??
So the centre support is on the steel Valance or the plastic or both???
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's Last edited by cnc; 01-06-2020 at 08:09 PM. |
It was used on the steel valance panels used in 1970 - 1972. I don't think it was used on the plastic valance panels. It's been a very long time since I saw a plastic valance that was still intact.
Thread Tools | |
Display Modes | |
