Old 01-07-2020, 06:18 PM
geeteeohguy's Avatar
Gee, nobody said anything about only street engines, the topic was flat tappet engines. Flat tappets are used in all kinds of engines last I looked. The example that Driven used to illustrate about additives, and balancing the package. They happened to use 2 race engines because they show wear more rapidly. The point was made that too much ZDDP will cause more wear, not less. There is a point that the additive stops being beneficial, and causes galling and pitting.
The engine doesn't have to be a race engine, but I'm sure the blanket statement that, "you can't use too much ZDDP" made by you was only for street engines. It really doesn't matter as long as it's an IC engine, it applies to all reciprocating engines and wear properties of the oil.
I'll back this up. Too much is detrimental to good lubrication. The secret is in a balanced additive package. The best balanced packages come in ready-to-go oils, not home brew combinations of additives. I have and will continue to run cheap dino diesel spec Rotella or Delo in all my flat tappet cars. Have for years now, and zero issues. Teardown of the 400 in my '67 GTO to do a rear main and reseal 9 years ago at about 90k miles on the rebuild showed rod and main bearings that looked new, with no signs of wear. The engine was also spotless inside with no sludge or varnish. Good enough for me. I installed new gaskets and am running it. Expect to get at least 80k more miles before the next overhaul. The first overhaul was at 173,000 miles in 1988.
Jeff
