What are the benefits of the Moroso split rail pan? How is it better than a Canton or Milodon pan?
I have one on an engine I own. It's going in a tube chassis car, so fitment isn't an issue. But it would be nice if I could use this engine in my other car with a factory subframe too. I just finished modifying the factory subframe and putting in a removable center tube. I really don't want to redo it to fit the pan. |
Pain in the ass using that pan. Get a good stef pan JMO
Loved my Langer pan! Split it a few times to check pump, bearings etc. You won't go wrong. …. Eric.
Runner Up Q16 Norwalk 2013! |
I personally found the Moroso pan to fit quite a bit better than the Stef pan did.
There is no comparison between the Moroso and Canton/Milodon. Those are just stock type pans |
I screwed up when I cut out the center of the cross member. I made it wide enough for the split rail pan, but I assumed the pan was centered on the engine, but it's not.
Guess I'll swap the pan and pickup if I ever put the engine in my factory subframe car. |
![]() Quote:
If it's built right nothing to check .It does not make you faster your proof of that..lol |
Anybody got pics of the Langer split pan?
Not in my case Stef pan fits way better .. Made no different performance wise just shinier..lol
When you go fast. You hurt parts. Maybe you'll find out one day. Check my signature. LOL.
Did you try both?
If interested....I got a polished Stef's pan I'll part with.
Here's a couple.
Last one.
My Stef's fit like crap around the timing cover. Everyone has their own experiences with products
There are around (3) versions of the "Langer" pan. The split pan was the result of crower having a bad run on lifters where they manufactured the wheels out of a material that was too hard. At the time, crower was the only manufacturer that would make lifters for a Pontiac that were .904 in diameter. Before the split pan, it would take me upwards of 3 hours to pull out the broken lifter, drop the pan, clean out all of the broken parts and put it back together. I lost a race due to not being able to fix it in time so I made a split pan. Now, I can change a lifter in around 45 minutes. Since I worked with Jessel on lifters, knock on wood, haven't had any issues.
Very True
The Stefs pan needs some additional baffling in the sump area if you're going to spin a big stroke "4.5" over 6800-7000 rpm.
![]() 2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
You can get the Langer split pan with a few additional mods to fit a titan oil pump and both a robbmc "long" starter and a powermaster stubby.
This pan will fit a 4.250 Crank. Custom built by Jake. 7 Quart pan. Provisions for 1/2" NPT oil temp. gauge fitting.
Closed Thread |
Thread Tools | |
Display Modes | |
