The ad for this car:
https://www.harwoodmotors.com/vehicl...ls.php?id=1058 says when the car was judged, it was penalized for having a tri-power. Specifically, it says: " When it was first completed, it carried a factory Tri-Power setup which was incorrect for this particular car. After being docked those points in competition, it was retrofitted with a correct intake manifold and Rochester QuadraJet 4-barrel, which it wears today (the Tri-Power setup is available to the car’s next owner, please contact us for details)." So, there were 66 GTO's that did not have a tri-power carb.?
1965 Buick Riviera GS 1965 GTO Tri-Power convertible 1965 Jaguar XKE Series 1 Coupe 1967 Corvette L68 convertible 1967 GTO 400 convertible 1968 Camaro 396 SS/RS convertible 1969 Plymouth GTX 440 1969 Mach 1 R-Code Cobra Jet 1970 Olds 442 W-30 1970 Buick GS 455 Stage 1 1970 Dodge Super Bee Hemi 1977 Pontiac Trans Am W72 SE 1978 VW Beetle convertible 2011 Mercedes SLS 2013 Jeep Wrangler Rubicon |
Hilarious !
I thought ALL GTOs came with a Tri-Power Just about 90% of these 64-66 cars that I’ve seen at previous shows and the internet examples have 3x2s. Yup, at least they got it corrected by installing a Quadrajet. |
Just kidding guys ^^^^^.
It’s just another example of how misinformed these Specialty car people are. 64-66 GTOs that were built with the 4bbl. carburetor used the Carter AFB. Chris |
Ahhh....I was going to jump down your throat, Chris! I agree that the article writers are usually mis-informed on these old cars. As for how many tripower GTO's, it seems like 90% of the ones I see are 'dealer added tripower'!! Kind of like every '69-'72 El Camino I've seen for the past 20 years is an SS model......LOL...
Jeff |
Anyone know the actual numbers for how many '66 GTOs were factory equipped with Tri-Power? I'd imagine that it's very much the minority.
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
65 was one in every four, 20k out of 75k. |
Mr. 242177P nailed it.
1966 factory equipped Tri-power = 19,302. |
| The Following User Says Thank You to 60sstuff For This Useful Post: | ||
Oh, and the car in question doesn't have a Q-Jet, pictures tell a different story. And those aren't Firestone Wide Ovals either, they're Custom Classic Wide Tracs. Looking at the GTOAA's judging, that car was a lot closer to Bronze than it ever was to Gold. That writer doesn't have a clue.
I could be wrong but wasn’t the AFB carb used in 1966 Pontiacs and the “first” usage of the Quadrajet on a Pontiac not until 1967? If that’s correct then having a quadrajet on a 1966 GTO would not be factory correct.
| The Following 3 Users Say Thank You to 1969GiPper For This Useful Post: | ||
Good information to know, thank you! To clarify, the AFB carburetor was a Carter, correct?
You are correct, 64-66 4bbls are not Q-Jets, the only 66 Pontiac's with a Q-jet would be Lemans or Tempest Sprints.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 1971 Fiat 130 Coupe 3.2L SOHC V6, ZF 5-speed 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 05 Dodge Magnum 3.5L SOHC V6 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
| The Following User Says Thank You to camerjeff For This Useful Post: | ||
We built some not-quite-a-Pontiac Pontiacs up here...
/\ yes.
So for this particular 1966 GTO to be factory correct in needs to have a 1966 389 four barrel (AFB) intake manifold and the correct 1966 AFB carb. Not a 1967 or newer intake manifold and quadrajet carb.
You’d be surprised how many people think that all GTOs came with a 4-speed and Tri-Power.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
1966 Lemans, The GTO finally figured it out in 1967
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car.
Beautiful sprint Jeff! , I found what I believe is a factory air cleaner to a 66 sprint, it has a longer throat to the carb then an AFB has, Jeff what is it worth ? It’s not mint, but not Junk either, thanks mike
242177P...Was the GTO sold in Canada sold with a small block Chevy?
