Old 05-17-2020, 06:59 AM
Mark G Mark G is offline
Default Nitrous Cam / N/A cam
In general with a nitrous application I open the exhaust valve sooner to give the exhaust port more time to evacuate the cylinder. Since an oxidizer is being introduced to the cylinder in an attempt to burn more fuel and make more power, more spent exhaust gas is created as the result. To sustain power throughout the operating range with this added exhaust gas(especially at the high end of the operating range) and expel excess heat generated by the faster burn of the oxidizer being introduced, the valve needs to open sooner. Since nitrous burns so quickly, it creates a sharp spike in cylinder pressure early after TDC on the power stroke. Because of this more work is being put to the crank in a shorter period of crank degrees. The exhaust valve can be opened sooner without losing a lot of torque(if any in the usable operating range) which carries more power upstairs.
If the exhaust valve is not opened sooner in a nitrous application versus a cam optimized for the same engine but for motor usage, power will not carry as far into the operating range as it did on motor. Peak power will be made at a lower RPM.
This is caused by spent exhaust gas not being evacuated from the cylinder. Spent exhaust gas displaces fresh air/fuel charge and it also heats it up. Added power cannot be made by attempting to burn spent exhaust gas, let alone sustain at the level it was.
I also like to close the exhaust valve later in an attempt to expel the last bit of remaining exhaust gas present in the clearance volume. You don't want to force the piston to do the majority of the work in pushing the spent exhaust gas out on the exhaust stroke as that would incur a large pumping loss. The size of the motor, the piston speed it generates and the amount of nitrous used determines where the exhaust valve should open among other things. Opening the exhaust valve at the right point on the power stroke allows the pressure differential between in cylinder pressure and atmospheric pressure in the exhaust port to do the majority of evacuation for us. Opening the valve at the right point on the power stroke ensures that we incur the smallest pumping loss possible on the exhaust stroke by removing the most spent exhaust gas it can before starting the exhaust stroke. Opening it too early will expel cylinder pressure that could of been used to do more work on the piston driving it down and producing more torque. Thus slowing the car especially off the line and on the gear change. A car with a 2 speed trans may become an absolute turd if this happens. A 3 speed auto may not be affected as much nor would a 4 or 5 speed.
That said, not all of the spent gas will be forced out during blow down or on the exhaust stroke. Leaving the exhaust valve open a little bit longer and closing it later will allow the negative reflected wave that arrives during overlap to help pull that last bit of remaining higher pressure spent gas present in the clearance volume out the cylinder.
Yes you lose some charge doing this. The benefit to this is removing more spent gas from the cylinder means we can now cram more fresh charge into the cylinder than we could have had we not closed the exhaust valve later. This almost always shows a power increase versus closing the exhaust valve earlier in a nitrous application that operates at higher RPM's. A lower RPM nitrous engine may not need this as much as a higher RPM nitrous engine.
I like to close the intake valve later in a nitrous application as well. Nitrous engines that are utilizing large amounts of nitrous are timing sensitive more than likely. A later intake valve close event helps to bleed some cylinder pressure off by pushing some air/fuel mixture out of the cylinder from the late closing event. This also helps to soften the hit on a smaller tire car or one that needs some help in the traction department.
Intake valve open event I like to delay a bit to ensure that reversion doesn't occur at lower RPM's(coming off the starting line) and cause a nitrous backfire. I may be totally wrong in doing this, but I feel it helps. I normally only do this on heavy nitrous engines. ( Engine Builder words not mine) Please add your thoughts ..
Old 05-17-2020, 07:19 AM
This is my take NA cam will do just fine with small to even fairly large doses of nitrous; where a "nitrous" cam really comes into play is very large nitrous tunes where it is necessary to get the heat out of the combustion chamber ASAP. EVO (timing events) and how long the exhaust valve is left open is one of the primary considerations when talking about a true nitrous cam.
Old 05-17-2020, 10:02 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Looks like text book theory.
Go fast, see Elvis!
Old 05-17-2020, 10:15 AM
Scott Stoneburg's Avatar
Ok. That is a good explanation. Thanks for the info.
Old 05-17-2020, 10:22 AM
slowbird's Avatar
slowbird slowbird is offline
I would think all of that is heavily based on how much you're spraying. So Mark how much you planning on spraying?
Old 05-17-2020, 11:13 AM
Stan Weiss's Avatar
Can you ask him about some actual numbers. If we look at the turn force on the crank. Let say a 4.5" stroke with a 6.8" rod. This geometry will have the turning force raise quickly and peak at about 25 ATDC. It will then descend at a somewhat slower rate.
Edit. - Let me also add. What is the difference is CR between the N/A engine and the Nitrous engine? If I make the same peak cylinder pressure at the same degrees ATDC the lower the CR the higher the cylinder pressure will be later in the power stroke.
Stan
Pontiac Pump Gas List
Old 05-17-2020, 02:19 PM
500
Old 05-17-2020, 02:22 PM
Stan
I can ask ..
Old 05-17-2020, 11:47 PM
JD's Avatar
JD JD is offline
500
Mark, what lbs per hour nitrous?
Also, in the post in the for sales section you said you are looking for something with a standard journal correct? Have you considered a 50 or 55mm? I think you will have better luck in your request.
Here is something that some of the N/A guys ran at one point. Not sure if they still do.
Depending on the heads and rocker ratio the lift may be high and the intake duration may be a little big but the valve timings may be close to what you are looking for.
Name:	Bullet Roller.jpg
Jim
71 Firebird, best 1/8th mile time of 5.02 at 142 at altitude in Vegas
Old 05-18-2020, 08:46 AM
I wish I could run a 50 or 55mm cam I say 500 but some tunes are happy like dynos .My tune from Switzer Dynamic Nitrous 40 jet/ = 500 Thanks
Old 05-18-2020, 09:09 AM
What are is your take Paul you do lots of nitrous stuff.. Is a nitrous grind needed with a 450/500 shot.
Old 05-18-2020, 10:41 AM
I got thinking about your statement I could not use a 50/55 mm cam I don't have enough head flow (450+) to take advantage of the larger lifts with such a cam . my heads are in the 350- 380 range Plus cam flex should be ok with lifts under 800 .I am not trying to rotate the world just run 8 flat..
Old 05-18-2020, 01:05 PM
Stan Weiss's Avatar
Interesting. I have not played with the Nitrous part of my software for sometime. I get
43N / 33F / 950psi / 5.5psi
for a general starting point
Stan
Old 05-18-2020, 06:04 PM
Stan
40N/32F 1000 psi 6.0 psi thru a 73 jet. that is my tune
Old 05-18-2020, 06:27 PM
PAUL K's Avatar
You would definitely want to change things around if you are spraying that much nitrous.
Go fast, see Elvis!
Old 05-18-2020, 10:44 PM
That what I am doing now changing things around.
Old 05-19-2020, 12:03 AM
John Langer's Avatar
John Langer John Langer is offline
I never ran anything like that, close but not really like that...
Old 05-19-2020, 02:01 AM
Dragncar Dragncar is online now
Kinda sounds like he is asking for something a little more specific to me. Well......
Old 05-19-2020, 07:35 AM
And you would be right I was hoping he would Enlighten us more I know what I'm doing on my end I was just trying to create conversation
Old 05-19-2020, 08:08 AM
slowbird's Avatar
Why is it people expect professionals to give out hard earned info for free? Mark should call Paul and buy a cam from him if he wants to know what Paul would do.
Ron Walker (a customer of Pauls) has a pretty similar combo and he's running the ets Mark wants to run so Paul's been there done it.
