Do I still need a relay when using a thermal switch?
I am using this thermal switch for a fan on one of my fluid coolers: https://www.improvedracing.com/therm...00f-p-831.html
I'm so used to wiring up relays w/fuses to control electric fans (like for coolant radiators that draw 20+ amps), I didn't think that perhaps in the case of this thermal switch, that I may not need it. The fan I'm controlling only draws 7.2 amps, that switch is rated for 10 amps. Does this mean I don't need the relay in this case? I have a 25 amp continuous relay with a 30 amp fuse on hand, but if I can simplify my wiring, I'd like to. But on the other hand, if using a relay will make the strain easier on my electrical when it kicks on, then I'd rather go that route. Thanks!
1969 Pontiac Firebird Last edited by 92GTA; 05-21-2020 at 12:57 PM. |
Use the thermal switch as the switch to turn the fan relay on.
You need the main power to go to the fan from the relay.
So wire it as normal with a relay. Understood.
Thanks!
1969 Pontiac Firebird |
You don't need a relay. The current capability of the switch is higher than the load, so safe to use the sw without a relay.
Relays are cheap and easy to replace when their contacts get used up. Clay |
Yes this is correct Sent from my iPhone using Tapatalk |
Derale doesn't publish those in their specs so I have no clue. Better safe than sorry then with the relay.
You said you already have a relay check around as there are many ways to mount the relay individually or in a multi relay mounted application. I did this in my 70 Lemans and mounted the unit in the inner fender behind the battery. Very easy to get to and I really removed all electrical draw from the original harness to the relay box for the horn hi and low beam, AC compressor clutch, coil, starter solenoid and blower fan. I am really happy with it. It did take some time and a lot of thought and layout. I purchased the wire termination ends so I could cut the wires to the correct length and terminate them instead of multiple splices. Is it over kill? YES it is!
Good luck. |
Nice. I have all of mine attached to the top of my radiator support facing forward. Hidden and easy to get to by just removing that 1 metal closeout panel. I also have a dedicated body ground going to the radiator support for that reason.
Thread Tools | |
Display Modes | |
