You're lucky the seller "bailed" on you with those 15x6 Rally II's anyway. 15x6 didn't come on TA's.
You really need to get some 15x7 Rally II's instead. That's the size that came on a TA. They shouldn't be that hard to find, since they also came on Lemans and Grand Prix. Factory Rally II's didn't come any wider than 7" size. Any that are 8" are aftermarket. Not that there's anything wrong with 8" aftermarkets. Of course, 15x7 or 15x8 Snowflakes would be good choices too. The 15x8's would be best, but they're more desirable, so more expensive. 15x7's are cheaper, but look good too. Personally, I wouldn't pay more than about $40 each for a used Rally II wheel. You still need trim rings and center caps, so it adds up. And for Snowflakes, you just have find the best deal you can on some used ones. 15x7 Snowflakes are more common, so shouldn't be too expensive. I rather have Snowflakes, since they're less likely to be bent than Rally II's. And you only have to buy center caps for them. Well, other than the correct lug nuts for them too. Snowflakes use different lug nuts than Rally II's. On any of them, make sure they are measured properly and have the correct bolt hole pattern, 5 x 4.75". Some of those wheels are 5 x 5 pattern for big cars, which you can't use.
Steve F. |
