Ames Customer Satisfaction Forum Post a 'current' compliment, suggestion or issue with regard to an Ames service or product.
Old 06-15-2020, 09:42 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
This is your host that is causing the delays! Max Performance (formerly Performance Years) makes the collars. We have 145 orders. Our supplier has had troubles delivering this part. It's a pretty complicated product requiring several different operations including the spline, aluminum casting, cnc and wrinkle paint.
The reason why you can't cnc these collars is because the part that goes over the column and holds it in place (spline) is part of this assembly. It requires a very unique process as the spline is hardened and chamfered.
I'll double check and confirm whether that promised date is accurate.
Old 07-20-2020, 08:44 AM
Slick's Avatar
Slick Slick is offline
Okay, it is after July 17. Have you been able to confirm that the July 17 delivery date occurred? If not, is there a new delivery date? Failing that, and after reading some of the remarks about the quality of the product, I'd consider going another direction.
But for now, let's hope the assemblies are being put together for delivery.
Thanks,
Stuart
Old 07-20-2020, 04:15 PM
Slick's Avatar
Called Ames customer service today. No joy. No predictions. No idea when collars will arrive, or even if they will.
Insert sad face.
Old 07-20-2020, 06:52 PM
Ccass's Avatar
Administrator
Thanks,
Stuart
Sigh..... We kind of came through. They are produced and in route to us and this was done prior to the deadline. Sadly, there was a missed communication and they are arriving by boat. The new date is Mid August.
That being said, Of the couple non glowing comments about the wheels and/or the collars, if you consider that thousands have been purchased, installed and enjoyed, overall they would receive very high marks.
What we are admittedly guilty of is a very long delay in this last production run. Again I apologize. :(
Old 07-20-2020, 10:12 PM
scott70's Avatar
scott70 scott70 is offline
mid August is better than nothing...i don't know where on the waiting list I am . I know i got on it around the beginning of the year.
Old 07-20-2020, 10:20 PM
Slick's Avatar
You are probably ahead of me, I think I got on in February, but I don't remember.
Old 07-21-2020, 09:27 AM
Ccass's Avatar
Administrator
There is enough to fill all backorders. So once we get them and send to Ames, they should be able to fill all backorders within a day or two I would think.
Old 09-05-2022, 12:22 PM
burd burd is offline
Wow. That just crazy that happened.
Old 07-20-2020, 10:19 PM
Slick's Avatar
Thanks for the update. The CSR on the line was less well informed. I appreciate the sentiment and the apology, while not necessary, is very kind.
As to the "less than glowing reports", I'm still willing to see for myself! After all, millions of Chevy guys don't give Pontiacs very high Mark's, but hey, I do!
Stuart
Old 07-21-2020, 09:29 AM
Ccass's Avatar
Administrator
Stuart
In order for the Ames CSR to have known this info, they would have had to call us 'yet again'. You can't blame them for throwing their hands up at some point. We took so long, that's kind of what happens in this industry. You get tired of giving your customer a date, then the date is missed and you have to make excuses to all those you promised a date to.
Old 07-20-2020, 10:43 PM
1965gp 1965gp is offline
I am very happy with the condition of the wheels when new- as I said I ordered another one. I just would not expect them to last over 6 years. New wheel is on the car now and feels great.
Old 07-21-2020, 08:59 AM
scott70's Avatar
it will interesting to see what the measurements are. Here is one I got off a different vendor back in December and sent it back because it was damaged and it was the only one they had. Ames didn't have any at the time I think. People were complaining that when the collar was installed there was a big gap between the collar and the steering column. I never tried to install the damaged one but I did run a straight edge over the one end ,,you can see there is a slight gap where the part that will touch the column sits lower. I wonder if these new ones will be the same or with a bigger gap. The bigger the air gap will make the gap tighter between the collar and the column.
The Following User Says Thank You to scott70 For This Useful Post:
Old 09-05-2022, 11:26 AM
How did that break?
Old 09-05-2022, 11:49 AM
Slick's Avatar
I sat in the car after replacing the rear end and rear suspension. Grabbed the wheel as I went to start the car and it snapped.
I've pushed and pulled cars by the steering wheel. I was in a terrible front end wreck in my 70 Trans Am in 1979, one that bent the steering wheel. But I've never, ever had one break like this!!!
The Following User Says Thank You to Slick For This Useful Post:
Old 08-28-2020, 03:32 AM
Mike Kelliher's Avatar
Mike Kelliher Mike Kelliher is offline
Got mine today,,,,looks good. Hopefully the installation goes smooth.
Getting mine at the end of the week..ordered in May' 2020, cant wait to install..
Old 08-29-2020, 09:27 AM
Slick's Avatar
Mine showed up Thursday. A very kind lady from Ames called a few days before that and asked that I not say anything for a bit since she had lots of calls to make. Examined it last night, looks great. Rim texture and paint finish different from OEM but not drastically so.
I'm quite pleased with what I have and with the quality of Ames' CSRs.
Additionally want to thank Ccass for his information.
Stuart
Old 09-05-2022, 05:42 AM
Slick's Avatar
Default Broken Spoke
Well, it lasted two years' worth of almost all "shelf" time. My car has only been out for four cruises since installing the wheel. Got in the car yesterday and this is what happened.
I've tried rotating the picture, but with no luck, sorry.
Slick
Smilies are Off
