Old 06-17-2020, 03:52 PM
ejw's Avatar
ejw ejw is offline
Are any of you running alcohol using a fuel pressure reg w vacuum port ( vacuum reference) running to carb
Pro systems said I need one when using electric pump to help at idle and wot.
APD said do not need one and magnafuel said dead head reg w pro 500 pump would be fine
Old 06-17-2020, 04:55 PM
GTOGEORGE's Avatar
I have a magna fuel 500 pump and a aeromotive regulator, I only use return line from the regulator....the one at pump is removed and blocked off. I don’t use the reference/vacuum port on the regulator and it idles fine
GTO George
Old 06-22-2020, 05:43 PM
Probird's Avatar
Probird Probird is offline
Nope, My Aeromotive A2000 has a bypass at the pump that returns back to the tank. I send it to the front at 28 lbs, then its deadheaded with the large Holley regulator set at 8psi to the carb. Idles clean and has plenty at the big end. I believe in the KISS method if it works.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
2024 Chief of the Pontiacs
