Next time you think about a cheap rotating part take a look at this. Belongs to a guy I know here in Italy.
| The Following 4 Users Say Thank You to crustysarge For This Useful Post: | ||
Years ago Ford had that problem with their OEM fan blades. I learned not to stand bent over the fan with the engine running.
It was about thirty years or so ago.
He had just installed new mufflers and (I think) a new, open-element air cleaner. There were about six of us standing around the front of the Mustang chatting. He had the hood open and he was revving it up so we could be impressed by the 'new' sound. His final rev was probably to around 6k and the fan let go. Fan blade glanced off the hood and landed about 50 yards away, behind us. Water pump exploded with antifreeze all over the place. Lower hose was shredded. Water pump pulley jammed down between the timing cover and the crank pulleys and stopped the engine instantly. Alternator was spinning about 100k RPMS - sounded like a siren. Took about two minutes for it to slow down and finally stop. I've had a healthy respect for all fans ever since. Especially at any kind of RPMs. |
| The Following User Says Thank You to Joe's Garage For This Useful Post: | ||
I had an alternator fan come apart on two different occations. One time it went right through my 1964 gtos fender . Looked like as if it got shot by a shotgun . Second time was 2 weeks ago it cut the lower radiator hose almost in half and cracked the paint on the hood with a big dent I dont like standing by the fender anymore when messing with the throttle. Most people dont give it a second thought..
Imagine that hood was open and someone was stanging there! (SMH) Not good!
My Half AN Injun..... |
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
I saw this exact thing happen with a buddy’s ‘76 Trans Am when I was in high school. Went through the hood like a can opener. That was back when you could find a 70-76 TA hood at the salvage yard for under $250.
But no doubt - the lesson here is don’t spend unnecessary time under the hood of a running engine. Setting the timing at idle is risky enough. |
Related, and already eluded to...
Years ago if they used a mechanical fan, many Winston Cup teams used a inexpensive stock four-blade Ford fan. This four-inch Ford fan, originally built for truck years ago, was proven to be the most efficient and economical mechanical fan on the market. Many teams used it for short-track. The type of track often determined type of fan, for the super speedway most preferred to use electric fans because of the horsepower and fuel-efficiency advantages. Same today on many street cars. Side note- I think the article meant to suggest 4-inch blades. But not sure. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 07-13-2020 at 08:00 PM. |
Both times the fan gave warning and i ignored it. Never again. Next time ill know to just change it out for a new one..
I hope your friend was ok...
I'd like to think that the crease in the flex blades of that fan create stress risers, causing cracks to start after enough flexing. The reason I'd like that: because then I'd be more comfortable with the curved blades on the flex fan I just put on the Pontiac in my GMC!
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
The few OE failed fans I have seen all failed at the rivets that held the blades. But all the OE fans I have seen have cupped blades and not the sharp creases like the one in this thread. When a blade does come apart, the potential for damage and injury is very high. The fan I just installed in my 62 Catalina is a 19" 1970 Oldsmobile clutch fan. The blades are a 2" pitch, cupped design. stainless steel blades riveted to a steel hub.
That sucks!!
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, [email protected] in the quarter...still tuning. |
Had something similar happen where I worked. Maint tech came to me stating that a large 6' diameter axial flow fan was vibrating badly and shaking the structure. I ran out there with him and it was running smooth as silk, and was about ready to tear into him a little when I noticed fan blades impaled into the ground, the side of a building and some time later found two blades on the roof of an adjacent building! I was so glad that he came to get me when he did, and not stood there and continue to watch !
Jimmy M 68 GTO |
My buddy had that same thing happen to a 70 Torino with the scooped hood his made it all the way out. Very sorry to see that happen to you.
I've seen quite a few cars in the junkyard with cheap fan blades thru the hood.
Quite the amount of force behind those things.
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
I had a similar aftermarket steel fan blade go on my 75 Camaro back in 78. Just cruising about 45 mph. Took out the radiator and put holes in the shroud. Never used another one.
The Racefan blades are the same material huge semi truck fans are made of. Quite aggressive blade pitch and surface area, VERY light. Heavy fans toss belts. We drive ours with a HTD belt/pulleys ...no slip, ever.
My 68 likely will be getting one in 19". |
Knew a guy growing up that came within 10 minutes or less of severely injuring or killing his best friend. The fan when through the hood about that long after Doug had been standing over it with a timing light... Close call.
'65 Tempest 467 3650# [email protected] |
WOW!
More proof, you get what you pay for. Too bad, it appears as though it is a nice car. |
My buddies was not a flex fan it was a replacement form OReily. He was OK hood was not got a big dimple.
I had a buddy with a 70 TA have a belt let go and dimpled his hood. I'd never heard of that, then a few months later my 78 did the same thing!
I've had a water pump let go and dimple the hood, lol.
It also took out the radiator, the fan shroud, the fan, the belt, the clutch on the fan, and the overflow tank for the radiator. ![]() New hood, hood insulation, radiator, clutch and fan, fan shroud, overflow bottle, belt, and $2,000 later, it was back on the road. Would have been more if I had to pay a shop to repaint a new hood. Luckily this car uses an OEM plastic fan, so instead of going through things or piercing the hood, they tend to just break off. |
