A bit of a noob question. 69 Firebird. I'm replacing my timing chain cover. I have all the pulleys off and the bolt that holds the harmonic balancer.
The service manual says to "slide" the balancer off the crank. That's not happening ;-) Is there a technique I can use? Do I need a puller of some kind? Thanks, John
69 Firebird/TA clone |
Ya, you need a puller- you can rent one from a local parts place. Also, soak the front with a penetrating oil such as PB Blaster that you can get there as well. Let it soak for a wile and rap it with a dead blow hammer a few times during the soak time and it should come right off.
Sleddog, Iowa Humility is not thinking less of yourself, it's thinking of yourself less. C.J. Lewis God Bless the U.S. and the people that defend it ...
I know this is an old post, but I couldn't help commenting. I'm in the process of replacing the crank seal in my timing cover. I too have the shop manual and and couldn't help but chuckle as I read that line about "sliding" the balancer off.
JCRUZ was certainly right - that's not happening. It brought back memories of my days in computer tech support, where the mantra was that documentation is nice if you have it, but it also can, and will, lie to you.
Larry |
Pontiacs are only a slide fit, unlike other engines. I've pulled a number of balancers that will slide off with a slight tap......others, not so lucky.
Regards, Leigh Pontiacs I’ve owned…. 1960 Laurentian 283 1963 Laurentian 283 1976 Trans Am 400 1977 Trans Am 400 1951 Chieftain Flat head 6 1967 Firebird 400 convertible 1967 Firebird 400 coupe 1979 Trans Am 403 1971 Formula 455 (clone) 1969 Firebird 350 1968 Firebird 428 manual. Sydney, Australia |
You were correct LeighP,
Mine only seemed stuck. As I generally don't care to smack things with a hammer, I put a puller on it. As soon as the slightest bit of tension was applied, it popped loose and fairly leaped off into my hands. Of course with a touch of oil the replacement slid on without a hitch. I expect had I simply tapped it firmly with a rubber or plastic mallet, it would have popped loose. This is my first Pontiac after about 40 years of Chevys and it's always interesting to learn new things.
Larry |
