Unknown. I assume so. The machinist did the light hone because I switched to ARP studs.
1965 Pontiac GTO 455/469 w/ #48 Heads, '65 Tri-Power 9.25:1 CR Stump Puller Cam Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00 3.55 Rear Differential Front: 225/60R15 Height: 25.6" Rear: 275/60R15 Height: 28" |
Thanks to Tom S for going to the shop and documenting things with the machinist.
I just spoke to the machinist. Yes, there was some sort of crank radius problem or bearing failure on #5. Friction, heat, seizure... He measured endplay again and it was perfect. 6-8 thousands I think he said. He says that no regular guy can be expected to see or know this would be a problem. He is going to take all sorts measurements of the Scat crank vs. a stock Pontiac crank radius and those bearings to let me have technical info on the specifics of the failure. The crank is repairable with a 10 under grind. The radius (fillet) will need to be reduced or a different bearing used that is narrower or has an appropriate chamfer. The block is likely salvageable, but will need some work. Yes, it looks like a chunk broke off in the picture, I forgot to ask. That is for Monday. Regarding cleanliness of my assembly area. During assembly, I was constantly texting him with questions and photos. He noticed that I was working in my garage and sometimes in the driveway and didn't like that. I agree, but had no choice. He doesn't believe dirt or debris played any role in this failure.I'm waiting on Monday, then I need to contact Butler with the info about the crank and/or bearings and see where I am. Frankly, between the machinist and Tom, they've communicated that I didn't f**k it up, which is a relief. I can live with myself.
