Old 05-18-2020, 11:32 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Bill Hirsch has the best high temp engine paint, pricey but great ,and indeed it's still made!
I agree
Old 09-14-2020, 01:00 AM
MPKind's Avatar
MPKind MPKind is online now
The Dupli Color is darker than the Plastic Kote. Not sure if anyone else makes it. I still have a small amount of the 208 so I could get some mixed if needed.
Old 09-14-2020, 01:49 AM
lust4speed's Avatar
Probably just a coincidence, but after Plasti-Koat went off the market, it seemed to me that the Duplicolor DE1616 lost most of its metallic. I've also had trouble with the last several cans of the ceramic formula drying too fast and not laying down all that well. Used to wear a mask because of all the metallic particles in the air while painting -- no mask needed now, and just doesn't have the same cool look. Also, the Hirsch paint I've tried always had too much green for my liking.
Mick Batson
Old 09-14-2020, 08:22 AM
If it's the metallic 67-up color you're looking for, 1616 isn't the duplicolor number. I still have a few cans here I'll have to look for you but it's a 3 digit number for the metallic blue and a perfect match for 67-70. I also used a different number for the later blue used in 71-72 that matched perfectly to the custom mixed color that Scott Tiemann was using.
https://youtu.be/XqEydRRRwqE
Old 09-14-2020, 10:06 AM
Stuart's Avatar
Stuart Stuart is offline
Plasti-Cote 208 was for the early 1960s cars.
Old 09-14-2020, 10:17 AM
MPKind's Avatar
‘65 and older robin egg blue is what we’re discussing. Not the metallic blue.
Old 09-14-2020, 10:23 AM
Well, some of you are, I'm speaking to lust4speed who is talking about the metallic paint, which the egg shell didn't have any of, or shouldn't have.
Old 09-14-2020, 12:59 PM
lust4speed's Avatar
Here's a portion of a chart I downloaded from one of the private Pontiac sites. I saved the chart but not the source. Comments are from original poster:
1966-1970
Pontiac 6 & V8
Light Blue Metallic
Ames PN431 or N182
Bill Hirsch Auto Reported to be high quality paint.
Hirsch lists this is being used through 1972 which is incorrect!
Classic Industries Blue Poly 62200
DuPont 181-97219
HI-TECH Engine Coating EN-57
Krylon/Dupli-Color Pontiac Blue Metallic DE 1616
Martin Senour Pontiac Blue No. 636
Performance Years RPE482
Plasti-Kote 227
PPG/Ditzler 13255
POR-15 Pontiac Metallic Blue They recommend a silver base coat first. Paint is reportedly difficult to apply, takes a long time to dry and does not look exactly like the factory color. This color is no longer listed on their website.
Rinshed-Mason 266T21
VHT Paints VHT-SP142 Pontiac Blue Metallic
Mick Batson
Old 09-14-2020, 01:06 PM
lust4speed's Avatar
Robin blue from the same chart:
1959-1965
Pontiac V8
Light Blue
This color is well documented.
Ames PN430, N181
Classic Industries 59-60 Sky Blue 62180*
Classic Industries 61-65 Turquoise 62190*
*Not known why the two above are listed as different paints.
DuPont 76981-D
DuPont 93-76981
Krylon/Dupli-Color DE-1610
Performance Years RPE480
Plasti-Kote 208
PPG/Ditzler 11561
Rinshed-Mason 62-015
Mick Batson
Old 09-14-2020, 03:40 PM
dhcarguy's Avatar
X2 on Bill Hirsch engine enamel
Old 10-01-2020, 12:21 PM
Dick Boneske's Avatar
Any update on Plastikote 208? I realize it has been discontinued, which is too bad because it was the best aerosol I've found to the original '59-'65 engine color. The Duplicolor equivalent is quite noticeably darker. VHT, if I remember correctly is noticeably lighter. The Hirsh product is priced at $20.00 per aerosol can..
When painting engine parts and intake manifolds, the only practical method for me is aerosol cans. The Plastikote product was easy to apply, durable, and easy t obtain.
Ames sold the Plastikote product as their go-to engine paint. The replacement aerosol is part number PN430B. The Plastikote number was PN430 at $7.00 each, but now is $16.00 due to higher cost from a new vendor.
The first two pictures are of recent Tripower parts I've painted with Plastikote 208. The third picture is of the VHT equivalent. You can see it is very light compared to the original. The last picture is of Duplicolor 1610 vs. Plastikote 208 vs. some original paint on the cyl. head.
ID:	550688   Click image for larger version
ID:	550689   Click image for larger version
Name:	Pontiac Paint Color 005.jpg
ID:	550691   Click image for larger version
Name:	Pontiac Paint Color 002.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
The Following User Says Thank You to Dick Boneske For This Useful Post:
Old 10-02-2020, 12:48 PM
I called the phone number on the Plastikote spray can. After a few voice messages directing me to different numbers, I ended up with the Duplicolor technical help line. A guy named Joe told me that Sherwin Williams, their parent company, bought the Plastikote division of Valspar.
Duplicolor already has their DE1610 and DE1616 Pontiac engine paints, among many other engine colors, so discontinued the entire Plastikote. line. Joe was aware that there is a difference in their Pontiac colors and Plastikote versions 208 and 227. He said he will pass on my suggestion to use the Plastikote formulas as they are more accurate to the original engine colors. But, he said that's not likely to happen.
Here are two manifolds I painted yesterday. The darker one is Duplicolor DE1610. What do you think?
ID:	550732   Click image for larger version
ID:	550733   Click image for larger version
BONESTOCK GOATS
Old 10-03-2020, 03:54 AM
Cardo's Avatar
Cardo Cardo is offline
It looks green Dick. That's disappointing. Probably will have to start getting some mixed. Somewhere on the forum here was a thread with all of the forumlas in PPG. We'll have to dig it up and link it.
Old 10-03-2020, 10:20 AM
FYI I have used a lot of the DE1616 usually get the 6 packs and have found the color is not consistent between cans in the same case at times. You notice if you paint parts separate and then assemble engine have had to coat complete engine to even out color more than once.
Old 12-25-2021, 08:23 PM
younggto younggto is offline
Has anyone used Inline Tube’s INL15375 for 1966-70 metallic blue?
Old 11-02-2022, 10:47 AM
grivera's Avatar
grivera grivera is offline
Has anyone used the paint on JBP site, ITU Pontiac 59-65 Engine Paint Sky Blue ITU-INL15388, and can advise if it matches the old Plasti-kote?
https://butlerperformance.com/i-3164...46;brand:99918
Will Rivera
Old 11-02-2022, 11:16 AM
I’ve used both Inline Tube & Ames Pontiac engine paint. Both are very close to original, but I prefer Ames because they sell only Pontiac parts.
BONESTOCK GOATS
  #38
Old 11-02-2022, 11:19 AM
Duplicolor DE1610 is too dark, and, as previously stated, inconsistent.
When Duplicolor bought PlastiKote, they should have stuck withe the PlastiKote 208 formula.
BONESTOCK GOATS
  #39
Old 11-02-2022, 12:32 PM
NeighborsComplaint's Avatar
I like the Light Metallic Blue and sprayed my '71 engine with it even though it's not correct. I've tried the VHT and it was almost gray in color. The Duplicolor was so soft it scraped off with a fingernail. Rustoleum Hammered Finish Light Blue 7212830 worked better than either of them for the silver-blue metallic. The hammered finish is fine on cast parts as the texture is not noticeable and the color is better. By spraying light coats, you can apply it smooth without texture if needed. Not looking for originality, just the color and it's much more durable than the other two products.
Triple Black 1971 GTO
  #40
Old 11-02-2022, 01:52 PM
grivera's Avatar
Nice - looking for paint to touch up valve covers…
Will Rivera
