#1801
Old 07-10-2020, 09:17 PM
cgeise's Avatar
cgeise cgeise is offline
yup i was told 11.5 ish was best power --
  #1802
Old 07-11-2020, 05:03 AM
charlie66's Avatar
Hey Curt,
No room for a dry sump at this time. Current target AFR is 11.8, at full throttle the O2 datalogs shows that AFR varies on both banks from 11.5 to 12.1
Im curious to what side is 11.5 AFR ?
Are you using race gas or e85 ?
My Half AN Injun.....
  #1803
Old 07-11-2020, 07:55 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
The Left "passenger side" is a running slightly fatter. I'm using C16 fuel.
Name:	Raven AFR Sample.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1804
Old 07-11-2020, 01:33 PM
charlie66's Avatar
Thank you
  #1805
Old 08-28-2020, 11:15 PM
RAIV-Z's Avatar
Looking for a Garrett Turbocharger Turbine Housing PART# 408532-0034
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1806
Old 08-29-2020, 01:29 PM
cgeise's Avatar
have you checked with EXILE turbo in Calif??
  #1807
Old 09-02-2020, 07:31 PM
RAIV-Z's Avatar
Turbonetics came through with one housing and enough info to allow me find another, both will need some machine work to fit the turbos. We're changing from to 0.89 A/R to 1.23 A/R due to excessive back pressure.
Name:	2020-09-01 17.39.26.jpg
ID:	548550   Click image for larger version
Name:	2020-09-01 17.24.48.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1808
Old 10-02-2020, 09:28 PM
RAIV-Z's Avatar
After a little machine shop massaging, the Garrett housings should fit the Turbonetics 88's.
Name:	2020-10-02 16.30.15.jpg
ID:	550779   Click image for larger version
Name:	2020-10-02 16.30.30.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1809
Old 11-29-2020, 09:30 PM
RAIV-Z's Avatar
Mockup indicates some additional turbine housing machine work is required as well as some potential clearance issues with one of the radiators on the drivers side.
Name:	2020-11-29 14.14.02.jpg
ID:	555027   Click image for larger version
Name:	2020-11-29 19.56.13.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1810
Old 12-07-2020, 02:00 PM
cgeise's Avatar
you should be much happier with the performance and the lack of back pressure
  #1811
Old 12-07-2020, 03:02 PM
GTOGEORGE's Avatar
Did you guys ever get those new ARP2000 head studs?
GTO George
  #1812
Old 12-15-2020, 07:52 PM
RAIV-Z's Avatar
GTO George
Yes, haven't cut them down yet. Waiting for the block and heads to return.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1813
Old 04-20-2021, 05:41 PM
RAIV-Z's Avatar
The engine refresh took a bit longer that anticipated, short block is together and the heads are ready for assembly.
ID:	565072   Click image for larger version
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1814
Old 05-02-2021, 07:55 PM
RAIV-Z's Avatar
Getting closer.
Name:	2021-05-02 18.44.56.jpg
ID:	565823   Click image for larger version
Name:	2021-05-02 19.50.16.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
The Following User Says Thank You to RAIV-Z For This Useful Post:
  #1815
Old 05-11-2021, 09:08 AM
67'7F6'Bird's Avatar
https://www.facebook.com/groups/220092308823847
  #1816
Old 05-21-2021, 09:57 PM
RAIV-Z's Avatar
Loading up for a 2021 chassis recert. Still waiting on a few parts before we fire up the engine.
Name:	2021-05-21 16.51.02.jpg
ID:	567014   Click image for larger version
Name:	2021-05-21 16.51.08.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1817
Old 05-22-2021, 01:05 AM
pokey1 pokey1 is offline
very nice
1967 GTO, 467 roller motor, e heads ported, tremec T56 magnum 6 speed and
9" done. EZ EFI 2.0 with FAST dual sync distributor and separate nitrous system done. Track is at 4300 ft elevation. so far a best of 11.95@116. Suspension now getting dialed in...tubular front a arms with dual adjustable coil overs HR Parts n stuff rear bar and whole car lowered 3 inches..
  #1818
Old 05-24-2021, 06:15 PM
RAIV-Z's Avatar
The Raven's updated engine is running.
Name:	2021-05-23 18.13.31.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1819
Old 07-12-2021, 09:28 PM
Quote from Ed Page
"Update for the Raven’s first outing of 2021 after major drive train changes.
The engine seems to be running well from what we can tell. We were unable to make any full or half passes due to transmission slippage. 1st partial pass was off idle and started slipping in 2n’d gear. Engine Oil pressure looked good when cool, a bit low when hot. We were using VR1 20/50. We'll try VR1 50WT before adjusting the oil pump pressure.
On one of the passes, we lost one of the turbocharger bellmouths, looking for a Turbonetics 20817P. The transmission is out of the car and will be checked out by Automated Transmission early next week. Also looking for another Rossler TH400 transmission, promod preferred. We will be adding another sensor to monitor internal transmission pressure which could have pointed out we were having a problem with the transmission."
We hope to see everyone this Friday & Saturday at the STREET OUTLAWS event @ New England Dragway in Epping NH.
https://tickets.thefoat.com/StreetOu...s/event-36130/
https://www.facebook.com/events/4668...2?ref=newsfeed
  #1820
Old 07-13-2021, 11:49 PM
See Everyone this Friday and Saturday at the Street Outlaws event in Epping NH.
Name:	Ed Transmission.jpg
