#261
Old 10-10-2020, 10:52 PM
many birds many birds is offline
I’d never heard of King bearings when I was assembling my ‘68 400 stock crank engine. I was initially considering clevite. For whatever reason that I don’t remember, my machinist recommended king, and now 8k miles later, no problems.
  #262
Old 10-12-2020, 08:37 PM
wbnapier wbnapier is offline
I spoke to the machinist today. He's done with the diagnostic.
He is 100% sure the problem is with the #5 bearing. The bearing sits too far rearward, due to the locater tangs. This combined with an aftermarket forged crankshaft with the large fillet radius resulted in catastrophe.
"Too far rearward" as compared with an older Clevite bearing and modern FM bearing. The older Clevite bearing is defined as when they still ground the tear-drop relief in the #4 thrust face. That older series Clevite bearings and FM bearings would be no problem with a new aftermarket forged crankshaft. Of note, Clevite's new 10 under #5 bearing is equally problematic too, not just standard size.
The Clevite sales representative has visited the shop to view the problem and the machinist has emailed them some photos. The representative is scheduled to return to his shop in 1-2 weeks.
The machinist has set up my block, a series of crankshafts, and a series of bearings to run through the issue with them as a proper experiment. He is re-align honing the block later this week, but will pause after that so as to keep the set up pure for the testing.
Of note, he has some stock Pontiac cranks, Scat 400/455 cranks, and an Eagle crank he measured and the after market cranks (including mine) are 0.005-0.006 thousandth longer and therefore my endplay is fine, but rubbing up against the #5 bearing, not the thrust bearing. If I had tested end play with a stock crank, it would have been too tight. I don't know if I am communicating that correctly, but something along those lines.
He has reground my crankshaft 10 under, and there is no issue now, as the fillet radius is reduced from that.
The shrapnel in the oil pan is from the bearing, he doesn't see any issue with my block, but I told him I thought I saw a piece missing in a photo which is another photo illusion.
The collapsed spark plugs remain a mystery. He says there is no sign of mechanical interference and those cylinders show no sign of combustion having every occured. His best guess is a dropped them before install and they bent in. I told him no, that didn't happen, but there is no other explaination.
I'm going to contact Butler to see what relied I can get from their side and make them aware. I'll also start ordering parts.
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
The Following 3 Users Say Thank You to wbnapier For This Useful Post:
  #263
Old 10-12-2020, 09:59 PM
Glad your getting it figured out!
Also glad you took it apart instead of just trying to work on the plug situation.
  #264
Old 10-12-2020, 10:01 PM
Scott Stoneburg's Avatar
Glad you didnt give up, and are getting it back together.
  #265
Old 10-12-2020, 11:14 PM
tekuhn tekuhn is offline
You drove the car a fair distance before the seize, and surely you would have known if the engine was running on 5 cylinders. I tend to agree the spark plugs are a real mystery, but can't believe you wouldn't have detected that severe of a misfire if the gaps were closed from the first fire-up. Especially with a manual transmission and clutch where everything is transmitted to the driveline.
Hoping to finish a project while I'm still able to push the clutch in....
1963 Tempest Convertible (Ram Air IV w/4” stroke), TKX, 9-inch w/3.70 gears and triangulated 4-link) Pictures
  #266
Old 10-12-2020, 11:19 PM
I did detect the misfire. I thought it was A/F or timing. I didn't think it was a no fire in the plugs. My plan was to cruise for a few minutes then return home and figure out the misfire.
And, I used the temp gun on each exhaust port and all were + or - 10 degrees. So, I assumed all cylinders were firing.
Remember, this is my first rodeo... Not an expert.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
  #267
Old 10-12-2020, 11:40 PM
Ah, OK. I didn't realize it was missing from the beginning. Not being critical at all. Has me rethinking whether I need to pull an engine I've had sitting installed in the chassis and never fired yet. I'm pretty sure I used Clevite 77's. This bearing thing could have been easily missed. I think I do understand what the machinist is saying. When you measured your thrust end-play, the crank was stopping short of reaching the rear-facing thrust face on #4 and instead stopping because the crank journal radius was hitting the rear edge of the #5 bearing shell. That would explain the weird noise that you heard when you pushed in the clutch in the final moments before seizure. The number 5 bearing edge and crank journal radius was under extreme contact from the pressure plate pushing the crank forward until it failed.
  #268
Old 10-12-2020, 11:54 PM
Exactly. He said that with aftermarket crankshafts, specifically my Scat and an Eagle he measured, they are longer compared to the stock Pontiacs he measured. Either overall or in a specific area, I don't know.
So, when one measures end play, you get a good mesurement. This is a false measurement though. Had I used a stock crank, I would have had too little endplay with these bearings and known there was a problem.
I don't know what to suggest to you. Of course, based on my experience, I would tear it down. Remember, my machinist bought a 10 under set of Clevites, and same problem as mine. So, this wasn't a one off error.
I emailed Butler tonight. I want them to test the Clevites vs. FM.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
  #269
Old 10-12-2020, 11:56 PM
Does anyone know why Clevite no longer grinds the teardrop-shaped relief in the thrust bearing? Does FM or King do this?
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
  #270
Old 10-13-2020, 06:23 AM
Probably saving money?
(extra maching step)
  #271
Old 10-13-2020, 07:16 AM
charlie66's Avatar
When setting up a new set of bearing one should check the endplay with out the caps . If its good then go forward with the caps starting with the thrust. If good go to the next one and so on.. As you go the problem will reveal itself if there is one..
My Half AN Injun.....
  #272
Old 10-13-2020, 07:55 AM
Gary H's Avatar
Gary H Gary H is offline
Default Clevite Bearings
I don't use many Clevite bearings, mostly FM, but I don't ever remember Clevite having the reliefs on the thrust surface of the thrust bearing.
  #273
Old 10-13-2020, 11:06 AM
darbikrash darbikrash is offline
King does put the oil relief on Pontiac thrust bearings.
The thrust bearing on top came out of my 400, not sure of the brand, the bearings below still in the package are King.
[/url]
1964 Catalina 2+2 4sp, 421 Tri-power
1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM,
Holley EFI, DIS ignition.
1969 GTO 467, Edelbrock 325 CFM, Terminator EFI
1969 Firebird Convertible
  #274
Old 10-13-2020, 01:03 PM
chiphead's Avatar
chiphead chiphead is offline
The FM4040 (3" main) do have the reliefs in the thrust shoulders. They also have an oiling slot and not just a round hole to line up with the block oil passage.
Ditto to what Charlie66 says about checking each half of the thrust bearing. Sometimes the upper and lower halves of a thrust bearing are slightly different thicknesses at the thrust shoulders.
If you have .007" endplay with the upper insert only and .005" with the cap installed, there is a .002" misalignment somewhere. Usually requires feeler gauges between the thrust faces and the crank to find it. Then glass plate sand the thrust face of the tightest insert to get back to .007" with the cap installed. This prevents all the thrust load of the crank shoulder from being loaded on only the upper or lower half of the thrust bearing.
The Following User Says Thank You to chiphead For This Useful Post:
  #275
Old 10-13-2020, 06:54 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Interesting.
  #276
Old 10-13-2020, 07:58 PM
charlie66's Avatar
Also,as you tighten each cap down rotate the crankshaft to see if it locks up or gets tighter. After all checks out try rotating it while holding pressure to the thrust just like you would for checking end play.. If theres a radius problem it will show signs of wanting to get tight .
  #277
Old 10-13-2020, 08:11 PM
From Butler:
"We have seen this with every brand of bearing and it seems to be more a difference in the blocks to us (most likely core shift over time possibly?)
We just recently had the same issue with a 389 but this is something we always check and sometimes have to slightly narrow and/or re-chamfer the bearing.
This is just part of the blueprinting process and a step we always check."
I wonder what else is always checked that I don't know about.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
  #278
Old 10-13-2020, 08:54 PM
MarkS57's Avatar
MarkS57 MarkS57 is offline
From Butler:
Core shift? I can believe that of the rear main seal area but the main bearing saddles, thrust location and the bearing tangs- aren't they machined operations? As well, why no warning in the kit instructions? Hmmm..
65 Tempest, 400, TH400
86 Fiero SE 2.8
  #279
Old 10-13-2020, 10:06 PM
61-63 61-63 is offline
As someone above said we the end users must perform the quality control on products. It behooves all of us to buy some quality measuring instruments and learn how to use them. This thread has been an eye opener for me beyond what I already knew to be true.
  #280
Old 10-13-2020, 10:16 PM
mgarblik mgarblik is offline
You do get an appreciation for how well the original engines and all the internal components fit together and worked flawlessly for millions and millions of miles when weird stacked-up tolerance problems like this happen. I have built probably just under 100 Pontiac V-8 engines and I have never seen this problem crop up. But there it is and apparently Butler has seen it. Another little thing I will certainly check moving forward. I am glad the OP won't have a huge expense getting this fixed. A tough lesson for sure. My personal thank you for sticking with the Pontiac engine and getting it repaired so you can enjoy the car. It will be worth it.
