Old 08-01-2020, 01:52 PM
Scott Stoneburg's Avatar
Default WTB. 400 motor.
Looking for a 400 motor for a basically stock rebuild. Interested in seeing whats out there. Complete? Running or needs rebuild? Preferably in the Orlando/Tampa/Sarasota Fl. areas thats close enough to drive and pick up. Shipping would probably cost prohibitive.
Thanks.
Old 08-02-2020, 10:56 AM
If you pass through Virginia at some point I can fix you up.
Old 08-02-2020, 12:41 PM
Thanks. You never know. I'll keep it in mind.
Old 08-06-2020, 07:03 PM
Ross455 Ross455 is offline
Default 400
I’ve got a later model 400 with 6x heads id let go.. It’s the 557 block but fine for a stock rebuild.
I’d take $300 and could get it to you.
Old 08-06-2020, 08:29 PM
Sounds fair. Is it a bare block?
Old 08-06-2020, 10:09 PM
robert91gt robert91gt is offline
I have a crank, rods with arp hardware, 30 over pistons, xe284 cam and lifters. No block at this time. I'm in Lakeland parts have less than 5000 miles but crank will need a quick polish.
Sent from my SM-G973U using Tapatalk
Old 08-07-2020, 01:59 AM
Complete engine less intake, exhaust manifolds, and distributor.
I never ran it but turns through and should be good core. I can take a quick look at the internals and send pics if you are interested.
Old 08-07-2020, 01:35 PM
Yes I am. How would you get it here?
Old 10-05-2020, 01:16 AM
carsmymistress carsmymistress is offline
Did you settle on an engine ? I am thinking of pulling my 400 to drop in something a bit more beefy. Its built to RAiii specs on s 69 block. Doesn't need rebuilt. I'm south of Daytona.
Thought I'd throw it out there.
1969 Pontiac Firebird 400 Convertible
Don't drink and drive. I really don't want you as a customer
Old 10-10-2020, 03:36 PM
Dragncar Dragncar is offline
Is it a WT 4 speed block ?
Old 10-10-2020, 06:53 PM
ponjohn's Avatar
ponjohn ponjohn is offline
@scott - are you on facebook? There is a guy in Plant City with an 69 XH 400 for 450.00.
Old 10-10-2020, 08:54 PM
Donny1973 Donny1973 is offline
I have a complete 1970 400 in Central Florida. Check my posts for details.
Old 10-10-2020, 09:07 PM
Thanks guys. I have a member here that i am planning to buy from on his next trip to this area.
Old 10-13-2020, 09:28 AM
Speargun's Avatar
Speargun Speargun is offline
Hey Scott, I have a few blocks, 1 or 2 complete, in Ocala if your deal doesn't work out.
-Jeff
No!
Do not try!
Do! Or do not.
There is no try. - Yoda
1967 Firebird Restoration 2005 - 1/25/2017
Old 10-13-2020, 10:48 AM
craigs69's Avatar
craigs69 craigs69 is offline
I have a 1967 400, complete carb to pan. Distributor, coil, carb, fuel pump, starter is all still bolted to the engine. Pulled 30 years ago from a running car and stored in an unheated shed. Engine still turns over freely. Missing 1 original valve cover that was robbed for a project, but a different one was installed at that time to keep it sealed up.
325 HP big car engine
YE code block, casting #9786133, A057 date code
143 heads
4242S carb
Asking $800
Willing to put on a pallet for shipping.
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds.
