#281
Old 10-13-2020, 11:52 PM
wbnapier wbnapier is offline
You do get an appreciation for how well the original engines and all the internal components fit together and worked flawlessly for millions and millions of miles when weird stacked-up tolerance problems like this happen. I have built probably just under 100 Pontiac V-8 engines and I have never seen this problem crop up. But there it is and apparently Butler has seen it. Another little thing I will certainly check moving forward. I am glad the OP won't have a huge expense getting this fixed. A tough lesson for sure. My personal thank you for sticking with the Pontiac engine and getting it repaired so you can enjoy the car. It will be worth it.
Thanks for the kind words...
I just emailed Luhn to get a new set of cam bearings. That's my first purchase.
Working through the list of new gaskets and what not now. Most of them got mangled in the tear down...
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
  #282
Old 10-14-2020, 09:48 AM
tom s tom s is online now
I have a Xtra set of cam bearing I can loan you until yours comes in.Can take them to Mike today if it helps.Tom
  #283
Old 10-14-2020, 10:00 AM
Tom,
That would be great. I'm not sure if it would speed things up, but worth a try. Thank you.
Luhn hasn't responded to my email yet.
I've ordered the ones that are not teflon coated, item # PGCB-P.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
  #284
Old 10-14-2020, 10:27 AM
mgarblik mgarblik is offline
I see you are in CA, but if this helps....... PM me a list of what gaskets you need and I will send them no charge other than postage . I should have everything other than head gaskets. They would be a mixture of Fel-pro, Mr. Gasket and OE. Want to see you back on the road.
  #285
Old 10-14-2020, 07:27 PM
dmac dmac is offline
Is this something that would be caught by any basic shop assembling/installing a rotating assembly?
  #286
Old 10-14-2020, 08:04 PM
PontiacJim1959 PontiacJim1959 is offline
Most likely. But, if I am reading this post correctly, a shop did not assemble the engine, the forum member did.
That said, and not to be mean, there are things that many of us who want to assemble our own engines after the machine shop has done all their work, can miss or not even know what to look for. I myself have learned mostly from a lot of hands on assembly, and yep, screwed up. But, I wanted to assemble my own engines as well. So there is a learning curve if you don't do this daily and most times you won't encounter problems such as this.
I do a lot of reading and have many books covering many brand makes of engines to include Pontiacs, that go over "blueprint" practices for those high-performance and race engines. You can pick up a lot and even apply some of that to our Pontiac engines.
I know to check my bearings at those edges that will meet the radius/fillet found on the crank. The radius is important and having one makes the crank stronger. Race engines having race type cranks can have a very large radius just for that reason. So it is important to verify that if your crank has a good radius that your bearings have a chamfer so as to clear the radius or use a narrowed bearing. Some makers offer main bearings with the radius already cut into them. Rod bearings are the same thing.
But, if I did not know to look/check for this, then why would I? You buy all new parts, have the machine shop do the needed machining, and then figure they just need to be assembled doing all your basic assembly checks as the original member did. So nothing was really done wrong, it was just that something that would have never caused an issue with a stock crank became an issue with an aftermarket crank.
I think the lesson is that anything aftermarket really has to be taken to a machine shop who can them really give it a 100% inspection/check and even go as far as blueprint it to make sure the item is within spec and not just assume it is because it is new and right out of the box. Sad that has to be said, but quality does not seem to be what it used to be anymore.
Luckily, no major harm was done to the engine and all will be well and up and running again in short order.
Just my 2 cents.
  #287
Old 10-14-2020, 08:30 PM
JMHO,I love the Butlers,buy quite of bit from them.BUT from the email from them they knew there could be a issue and for sure there should of been something put in with the receipt to call attention to the issue.And I still have not found a narrow main bearing?H are for HiPo and X is for 1 thou more clearance but find nothing with a N like a narrow rod bearing?Tom
  #288
Old 10-14-2020, 08:54 PM
NeighborsComplaint's Avatar
From Butler:
"We have seen this with every brand of bearing and it seems to be more a difference in the blocks to us (most likely core shift over time possibly?)(
quite possibly the stupidest excuse I've ever heard. Core shift occurs during casting and results in the off-specification location of a casting feature where there are voids needed in the casting. The core forms the void. When the core shifts, the void is formed off the intended location. Core shifts do not occur over time, the core is long gone from the casting process and the void is where the core formed it. Cast iron doesn't bend to allow a cast-in void to change position over time.
Basically Butler sold you a crankshaft kit of mismatched components and wants to pass the buck on the failure off on the "machinist/installer" knowing you are a novice. That's like them saying "We will rebuild your heads but you need to check all our work as additional machining may be required before you install." Jeezus, if you go to Autozone and buy any crappy re-ground crankshaft kit, the bearings fit the crank without machining.
The other thing I find unbelievable is that you were unable to discern an 8 cylinder engine was running on 5 cylinders. I can easily discern a single fouled plug on startup. When driven, the loss or power is much greater 12.5% (7 of 8 firing). With 3 cylinders down, you would have barely made it down the driveway much less drove it down the highway. Seriously? [B]Nobody[/B} drops 3 plugs in a row, lands them square on their electrodes so as to perfectly close their gaps, then installs them not noticing the gaps are closed. I have been wrenching on cars and snowmobiles for over 60 years and have never once seen a sparkplug come out of the box with the gap closed either.
I still say there's lots more to the story you are unwilling to share and I'll leave it at that.
Triple Black 1971 GTO
  #289
Old 10-14-2020, 11:22 PM
As stated, I am not an expert on engine building and am sure you have more experience than myself, but I found a few interesting things in an article on the web. I realize that rod bearings come in narrow widths - which is more of what I was leaning to. The chamfers on the main bearings I did find available for a small block. I also know that you can purchase a tool to chamfer bearings, but of course the average guy with an electric drill and vice isn't going to be doing this.
Clevite & King sell a .001 narrowed main bearing set (also .002 for Clevite) and King main bearings do advertise the chamfers for large radius cranks.
Here is what I read: "Taken as a generalized statement, stock replacement rod bearings are often slightly wider than their high performance bearing cousins. To illustrate this point, we measured the width of a set of stock replacement aluminum Federal-Mogul connecting rod bearings for a big-block Chevy compared to a set of Federal-Mogul (Speed-Pro) performance tri-metal bearings. The stock aluminum versions measured 0.885-inch while the performance bearings were 0.020-inch narrower at 0.865-inch. Using the wider bearings on a performance forged steel crankshaft could cause the outer edges of the bearing to bind on the larger fillet radius of the crankshaft. This could cause immediate bearing failure, and at the minimum will cause bearing debris to be released into the oil."
Now I found this interesting and thinking out of the box, is it possible the bearing halves were mixed up at the factory? I realize you align the oil hole in the bearing half with the oil hole in the block, but what if the wrong half got drilled at the factory? Why I ask is that this same article mentions the register tang position having an upper & lower position to the bearing half - this is again in regards to a rod bearing, but could this apply to a main?
"Narrowed bearings also brings up the issue of rod bearing chamfers. Most performance rod bearings are designed with a chamfer on one side of the bearing to accommodate the large radius on the edge of the journal. Since the inboard side of the bearing avoids this fillet radius, there is no need for a chamfer on both side of the bearing. But with both upper and lower bearings, this demands that the bearing be placed in their proper orientation. Because the bearing is located by its tang, a chamfered bearing must be installed either as an upper or lower bearings since the chamfer will be on the opposite side for a lower compared to an upper bearing half.
This requires performance rod bearings with these chamfers to be marked “upper” and “lower”. Some bearing companies abbreviate this by using “U” and “L” as stamped on the back side of the rod. If these bearing halves are incorrectly installed, the bearing’s flat edge will face the fillet radius and create immediate bearing wear in this location–often the rod will even bind once the cap is torqued. "
I read that the bearing tang was slightly off. Is it possible the factory.manufacturing source had the bearings flipped and drilled the oiling hole in the wrong bearing half thus positioning the tang in the wrong place and pushing the bearing in the direction of the crank radius rather than away from it? Just thinking here knowing how quality control can be - especially if outsourced from overseas.
  #290
Old 10-15-2020, 12:44 AM
NeighborsComplaint -
1) I am not satisfied with Butler's answer in the least. I have 19 years experience with casting in an unrelated field, and I found their answer patronizing and have not responded.
2) Based on the spark plug thing, it is understandable you are skeptical and think I am leaving some info out. I have absolutely no logical answer to explain the 3 closed gaps. I absolutely did not drop them. I gapped them all at .045 and double checked each. It is ALSO TRUE that there is no sign of mechanical interference, debris, nor combustion. It is ALSO TRUE that they don't come out of the box closed. So WTF happened??? I have no idea. My machinist thinks that I HAD TO HAVE dropped them. I cannot argue with his logic either. I have to move on.
I have been playing with cars since 2016 when I bought the GTO. I am a novice, but I immediately knew there was improper combustion at part throttle. I didn't think I was missing 3 cylinders. I assumed timing or AFR. This was the first time in my life I had ever fired a new engine. I chose to drive it a couple miles before addressing the misfire. On was only misfiring on partial throttle under load. The rest is history.
You may wonder why a novice would take on such a big project. I am mechanically inclined, have good friends with lots of knowledge, and have successfully done all sorts of work on the car. I thought it would be fun to try. Guys have been rebuilding these engines in their garages for 50+ years, so why not me?
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
The Following 4 Users Say Thank You to wbnapier For This Useful Post:
  #291
Old 10-15-2020, 01:05 AM
I read that the bearing tang was slightly off. Is it possible the factory.manufacturing source had the bearings flipped and drilled the oiling hole in the wrong bearing half thus positioning the tang in the wrong place and pushing the bearing in the direction of the crank radius rather than away from it? Just thinking here knowing how quality control can be - especially if outsourced from overseas.[/QUOTE]
I am hoping that the Clevite rep takes an interest and answers these questions.
For the record, I have no illusion of financial relief at this point. Just intellectual curiosity.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
  #292
Old 10-15-2020, 08:51 AM
MarkS57's Avatar
MarkS57 MarkS57 is offline
Good!
Yep, fall 2023 will be the 50th anniversary of my 1st engine rebuild, a 62 389. It was a ton of fun, absolutely. I have not rebuilt near as many engines as some have on this site though. I've never used an aftermarket crankshaft in any project to date. My next build will be a 428 w/ a stock crankshaft.
65 Tempest, 400, TH400
86 Fiero SE 2.8
  #293
Old 10-15-2020, 09:31 AM
Sirrotica's Avatar
I'm kind of surprised of the content of that E Mail. Although I've never done any business with the Butlers, I have shared an adjoining spot on the manufacturers midway at Norwalk for 7 years, and have had occasion to talk to them during the event in the course of selling my Pontiac themed T shirts.
One year there was someone displaying a crank that was pretty much destroyed in the swap meet, that was from an engine that had problems, alluding to the crank was bought from the Butlers, and was alleged to have been defective when bought, causing the engine to fail. The situation got back to the Butlers and they went and discussed the situation, and came to some type of understanding that the aggrieved party was going to get some type of compensation for their trouble.
From the story I was told, it didn't sound to me that the crank was the fault of the vendor, but in a leap of good faith they were willing to do something to help out the customer.
I've heard that some of the employees in the past have been abrupt on the phone with customers, and that the owners would have been less than happy with the responses from their employees. In my speaking with them over the years they're nice, fair, people. I'm wondering if the E Mail was from an employee, rather than one of the Butler family.....
The core shift response sounds like a far fetched reach in trying to explain away what happened with the rotating assembly. Just kind of surprised at that response.
I'm in agreement that core shift happens during the casting process when the block is made. It has little to do with how main bearings sit in the block decades after the fact. IMO, If anything, the factory machining initially would make a problem, not core shift. FWIW.
I have a friend that builds his own SBC oval track engines, when he stepped up to using aftermarket cranks over factory pieces, he also ran into the radius problem on rod throws. He caught the interference problem and had to order the relieved rod bearings to solve his problem. The Pontiac community doesn't have anywhere near the choices of bearings that SBC builders do, we sometimes have to modify the bearings themselves rather than buy a bearing that fits our applications. Just a fact due to the supply, and demand in our small circle..............
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #294
Old 10-15-2020, 12:10 PM
dataway's Avatar
dataway dataway is offline
I don't know if my experience is typical, but I bought a stock crank from Butler, turned .010" . Had to be remachined to fix it, journals varied by close to .001. And the key was still stuck in the dirty crank snout so well I had to TIG weld a piece on it to get it out.
However ... Butler does not do the machining on their off the shelf stock cranks, it was machined by Lunati. At least that was the case a couple of years ago.
  #295
Old 10-15-2020, 01:31 PM
Sirrotica's Avatar
Just for clarification, the crank was a new in the box, cast 455 replacement crank, not something that was refurbished factory style.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #296
Old 10-15-2020, 02:58 PM
lust4speed's Avatar
I would expect to see the rear edge of #5 bearing tore up if the problem was the radius contacting the bearing. Instead it looks like either the block bearing journal was machined smaller at the rear or the bearing was thicker at the rear. Possibly the guy running the hone was pulling up short or there was another problem? The journal size can still be measured to rule this out. Also, a short radius touching the bearing would attempt to spread the bearing and damage would be much more centralized at the rear. I use Clevite bearings because the FM Babbitt thickness's were all over the map while the Clevite's were much more uniform, but...
How did #4 thrust spin 1/2" or so and the tangs are still perfect?
Don't think we will ever figure out the plugs closing up or the chipped cam gear.
Just think we're going down the wrong rabbit hole chasing the position of the rear bearing.
ID:	551446   Click image for larger version
  #297
Old 10-15-2020, 03:11 PM
The #4 bearing was a optical illusion.It was in the proper position when removed.There have been other reports of rear main bearings on pontiacs.Not a one time issue.Tom
  #298
Old 10-15-2020, 04:55 PM
Dragncar Dragncar is offline
Core shift can not cause this issue. Its crazy to try and blame it on core shift.
Did the OP not spin his crank when torqued down ? There is a lot missing from this story. Plugs with closed gaps ???? When there is nothing about the bearing/crank fit that can cause the gaps to close.
If there was 3 plugs with closed gaps, what it tells me is there is more wrong with this story.
Right now I have a Scat 4340 crank in a block with FM performance bearings. Crank has the large radius's. Spins perfect in the block.
It just goes to show you that every little thing needs checked with these engines. Once you change a part like a crankshaft from OEM to aftermarket, take nothing for granted.
  #299
Old 10-15-2020, 05:03 PM
Just my 2 cents.
Long ago Dan Whitmore told me the Pontiac V8 and the small block Mopar had the same oiling system. So he used information that came from the Mopar circle track guys who raced them back in the day. Transferred it to our Pontiacs.
Its good to read stuff about other engines.
It looks like a somewhat happy ending for the OP. Hope he gets it back on the road soon.
  #300
Old 10-15-2020, 07:40 PM
Is there a way to check for this problem on an assembled short block? I had a shop clean, bore, hone, and assemble a 455 block with a rotating assembly kit from Butler. I am pretty sure it had the FM bearings, but had a cast stroker crank, not forged. Spins pretty easily by hand, but that probably means nothing. Because I supplied all the parts, I doubt if they were checking at the blueprinting level.
