#221
Old 08-23-2020, 03:48 PM
Yes, training base, T-38's, similar purpose to smaller base, Vance an hour from me.
  #222
Old 08-23-2020, 05:12 PM
SD455DJ SD455DJ is offline
Originally Posted by scott70 View Post
I dynoed my # 64 headed 455 with 1 3/4" hooker headers and then switched to RA manifolds with 2.25 outlet dumping into 2.5" mandrel bent headpipes. About 18 HP and tq. difference.
Here are the actual factory round port manifold outlet sizes 2-1/16" and 2-1/8" that the 455HO was dyno'd with. I might just have to get a pair of the 2-1/2" outlet RARE manifolds. It was shocking to see these had the same outlet size as the regular log manifolds!
Dennis
Name:	455HO Driver Outlet.jpg
ID:	547806   Click image for larger version
Name:	455HO Pass Outlet.jpg
  #223
Old 11-06-2020, 09:30 PM
Dan got some of the other project cars moved out of the garage making room for the GT-37 to move into the 'work' bay from the storage side. I decided to remove the A/C system and bought an AGM Ind. AC Delete kit for 68-72 A-Bodies. It comes with a nice fiberglass cover (not ABS plastic) with a new heater core, blower motor, custom cage fan, and sealant for the cover to firewall. It retains the controls function (except A/C of course) and the under dash ductwork and plumbing. We'll be taking pictures of the installation along the way in case anyone is interested in similar conversion. We'll be going through the brakes, suspension, rear end, and new exhaust along with the 455H.O. install with the rebuilt Borg Warner Super T-10 wide ratio 4-spd (2.64 1st gear). I need to order a new headliner kit from Ames and see what I can do with the original door panels. Actually, the passenger side is OK, the drivers panel is ripped at the top along the window, so hopefully we can replace that little section of white vinyl ourselves. We have a new black carpet set for a bench seat car with floor shifter that wasn't used on another A-body project, so it's going in the GT. The newer dash is almost assembled and ready to go in along with a nice older formula wheel to replace the original dry rotted one.
Dennis
ID:	553170   Click image for larger version
ID:	553171   Click image for larger version
ID:	553172   Click image for larger version
Name:	68-72 AC Delete Master Kit.jpg
  #224
Old 11-08-2020, 07:38 PM
The weather couldn't have been nicer for November in Michigan (low 70's, dry and sunny), so we took advantage of it and made a bit more progress today on the GT-37 by striping off the rest of the AC system and removing the under-dash case, then removed the pedals and brackets to rebuild and refinish. We pulled to facilitate the inner fender removal and the rest of the suit-case and evaporator. Then we made a 2 page list of parts to order from Ames...ouch!!!
We found a small spoon in the vent that feeds the defroster ducts...not sure if that was left at the factory, or Mike (455HOGT37)…??? Maybe Mike knows 'the rest of the story.'
Dennis
ID:	553374   Click image for larger version
ID:	553375   Click image for larger version
ID:	553376   Click image for larger version
ID:	553377   Click image for larger version
  #225
Old 11-09-2020, 08:06 AM
Here's pic's of the evaporator removed (before & after), the interior AC box removed (to be cleaned up and reinstalled) and Dan removing the wiper motor & pump (needs a new one). We removed all the firewall sound insulation and pads and they were responsible for holding moisture against all the sheet metal causing a bunch of surface rust, but no rot, thank goodness. We're going to remove it and spray a sealer on the metal before the new insulation and pads get installed. We need to get a new front speaker for the AM radio, but wondering if modernizing the audio system would be a worthwhile upgrade while its all apart. Next is to test fit the AC Delete firewall heater box.
Dennis
ID:	553448   Click image for larger version
ID:	553449   Click image for larger version
ID:	553450   Click image for larger version
  #226
Old 11-13-2020, 11:51 PM
455HOGT37's Avatar
455HOGT37 455HOGT37 is offline
I know nothing about a missing spoon! I'm not sure I ever had the A/C system that far torn down.
  #227
Old 11-16-2020, 08:28 AM
Mike, it probably was a factory lineman stunt. I've heard of things like this happening every now and then. It must not have ever rattled around or buzzed when you had the fans on. It's not going back in, lol!
We are going to use some Loctite Extend (or Permatex's version of it) rust neutralizer on the rusty areas after wire brushing the loose stuff off and follow up painting it with matt black paint. Then bead blasting the brake/clutch pedals for new paint and install new bushings. We'll clean and check out the inner heater/ac box for reinstallation, then onto getting the dash back in. We got a bunch of parts from Ames (firewall insulation, kick plates/panels, e-brake pedal, etc. to get the interior looking better.
Dennis
  #228
Old 11-18-2020, 08:40 AM
I took the day off yesterday to work on the GT-37 with Dan. We spent the whole day neutralizing the surface rust with Loctite Extend and then installing the new firewall insulation cover, inside heater box and new AC delete cover in the engine compartment along with the supplied new heater core, fan motor and cage fan. We were surprised we got it done in a day. The new fiberglass firewall box/cover isn't drilled at the attachment points, so there was a lot of on & off, and for the fan motor and aux hose too. The worst part was the smell of the Extend when fresh, so we used a floor box fan to dry it faster and evacuate the fumes.
Dennis
ID:	554211   Click image for larger version
ID:	554212   Click image for larger version
ID:	554213   Click image for larger version
  #229
Old 11-18-2020, 05:53 PM
It looks like the re-circulation vent in the passenger side kick panel was removed some time ago with a homemade sheet metal block off cover, a little duct tape, a couple of sheet metal screws, and a liberal amount of silicone sealant...viola, hole sealed! We just left it in place as it wouldn't affect the performance of the new non-AC system...too much.
Dennis
  #230
Old 11-20-2020, 04:56 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
Dennis
Looks like my handywork.. HAHA Love this car Dennis, love watching the progress. Dan's car made me into a Canyon fiend as a young man, and i love seeing all of them!
  #231
Old 11-20-2020, 05:16 PM
Thanks Adam. Dan's T-37 sure was an eye-opener back when he started racing and showing it over 35 years ago. Now I have 2 canyon cars too, this GT-37 and the Formula 455HO. This GT-37 isn't going to be as nice as the Formula (or especially Dan's T-37), but it's sure going to be fun to drive. Thanks for following along.
Dennis
  #232
Old 11-20-2020, 06:49 PM
trishieldchief's Avatar
I agree Dennis, your GT-37 is mega cool, major fun filled car.
Rich Johns
www.purestockauto.com
1970 GS 455 M21 4 Speed 3.42
1987 GN Astro Roof
  #233
Old 11-21-2020, 10:46 PM
Thanks Rich! I'm sure I'll piss-off a few people that think this car should be restored (and it should some day, but not by me...I can't afford that expense) and with changes I'm making, but at my age, I want to get it back on the road to enjoy driving it and not be worried about scratching a 35k paint job and getting the underside dirty. I'm still thinking about blowing some faded Canyon Copper paint on the primered spots and adding new GT stripes, but we'll see as we get further into it. The biggest deviation I've made is removing the factory AC system for the AC Delete kit, but I never liked AC on any GM A-body (or F-body).
Dennis
  #234
Old 11-22-2020, 05:39 PM
Talking
Dennis driver quality patina cars, produce the biggest grins
Rich Johns
1987 GN Astro Roof
The Following User Says Thank You to trishieldchief For This Useful Post:
  #235
Old 11-22-2020, 07:33 PM
Agreed Rich! We made a bit more progress this weekend by removing the front valance to get the AC condenser/dryer out along with the original front wire harness (lights/horn). We replaced the old harness that had some spliced wires with a 'newer' original uncut one. We also cut in the hole in the new heater case for the blower resistor and the hood tach defroster line nipple, rivet and all. We got a front end fastener kit from Ames (AMK) to replace the variety of bolts that were installed in no particular order, or just MIA. This GT-37 is proving to be a fun challenge in the re-assembly process.
Everyone have a great (and safe) Thanksgiving!
Dennis
  #236
Old 11-22-2020, 07:37 PM
...here are the pics I forgot to post...
ID:	554564   Click image for larger version
ID:	554565   Click image for larger version
  #237
Old 11-23-2020, 11:28 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Dennis, is there any trick to getting the inner fender out? I need to change a heater core on mine and took all the bolts I could see out and it wouldn't budge.
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
  #238
Old 11-23-2020, 03:18 PM
pggto's Avatar
pggto pggto is offline
I just did the heater core on my 71 GTO non AC car. I had to remove the rocker molding, the lower fender bolts, the inner fender well to fender bolts in the front of the wheel well (there's a bracket that attaches the two), the washer fluid jug, and all the inner fender bolts. Then you have to pull the lower fender outward and rotate and flex the inner to clear the upper A arm. At least that's what I did to get mine out, I wasn't to worried about scratching the inner on this car.
The heater core comes out from the inside of the car attached to the inner heater box, so you need to remove the inner glove box and disconnect all the cables and wires before you remove the box. The core is held in with a couple of spring clips.
Don't forget to replace the blower motor while your in there and clean out any mouse nests. Which is why mine had to come apart.
ID:	554628   Click image for larger version
The Following User Says Thank You to pggto For This Useful Post:
  #239
Old 11-23-2020, 04:00 PM
OCMDGTO, Yep, just like pggto said, just remove all the bolts that attach the inner fender AND the 2 bottom fender bolts. I was able to remove my fender well with the rocker molding on, but was very careful not to bend it when I pulled the lower fender out an inch and with tugging/twisting the fender well to make it drop out. Just go slowly...you may want to remove the rocker molding just to be on the safe side.
Dennis
  #240
Old 11-25-2020, 07:13 PM
We are waiting for some original parts to arrive, so progress has slowed a bit, but in the meantime we glass-beaded the rusty clutch/brake pedals and mounting brackets along with the steering column collar that attached to the firewall. We are replacing the parking brake mechanism with a repop from Ames that isn't 100% correct, but looks much better than the rusty original. The under-dash area is starting to look pretty nice...unfortunately most people will never see that, but it's nice knowing it is mostly rust free now and protected.
Dennis
ID:	554750   Click image for larger version
ID:	554751   Click image for larger version
