Went to the track a couple weeks ago and my Catalina ran 6.59 at 108.95 foot braking.Original block and heads 400 stroked to 461 ,75mm turbo,small hyd roller,UCC convertor,Jake's stage 3 th400 kit,9in rearend with a 3.50 gear.Best of all,I can jump in it and drive anywhere.
I don't know how the hell to get these pics upright. |
Nice!!! So what is that in the 1/4? 10.50?
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
Thats pretty close.I think I have the potential to run a high nine.That will be my goal next year
With that 60' time, if it would launch good, it would be a LOT faster. ![]() Good run and good looking 'land yacht'
| The Following User Says Thank You to johnta1 For This Useful Post: | ||
Thats running very good on the top end. I think that 6.59@108 will get you in the 10.30s in the 1/4.probably in the 135 mph range.
Wow now that's a sleeper!
Chris D 69 GTO Liberty Blue/dark blue T400, 9" w 3.50s, 3905lbs 461, 850 Holley, T2, KRE 310s, Comp HR 236/242D .572/.594L, RA manifolds, 11.53@114, 1.55/60 The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, Howard HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60' |
Very nice! You will definitely be hurting some feelings with that car if you haven't already!
Greg Weigart IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/[email protected]/[email protected] Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 - Quickest Pontiac 2022 - 10.13 @ 133.07 2025 - [email protected] - 2nd place SRBBNA
awesome job, is that blow thru or efi?
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
Yes, definitely a sleeper! Have you run the car across a scale?
Sent from my SM-G965U using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
CSU 750 carb and weights 4240
Have you tried a bigger carb?
Hauling. |
I've got enough carb to split the block right down the middle already.
| The Following User Says Thank You to oethel For This Useful Post: | ||
😂😂😂 That car is bad ass!!
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas |
That's hauling the mail, How big are the rear wheels ? The car looks tubbed on that picture.
Definitely my kind of car!!! |
How much boost?
Intercooler? Engine bay pic? Cool car! |
No tubs and a 12in wide 750 series Sander wheel with 275/60 radial pro rubber at 18psi.I put hi-tack on the beads to help keep from slipping. no beadlock and one of my tires moved on the rim about a inch.see the white mark?I believe that 6.59 run was 13-14lbs boost.I'm using a treadstone #1245 innercooler.
That first pic of the engine is a mirror image.still try too figure this damn picture problem i got. |
All that car needs now is a flawless coat of shiny black paint.
Nice work, -Abone.
Daily Driver Model A Ford. 389 Pontiac w/6-71. 10.80 @129.5 1933, 1934, 1936 and 1940 Fords, also Pontiac powered. |
GT |
How did the wastegate work for you?
Great times so far!
My Half AN Injun..... |
Paint don't make it any faster,but your right,it needs a nice paint job....the 7K3 heads are original to this car and have stainless valves,10 degree locks,lash caps and Teflon seals.Butler street ported these heads in 98.I had Butler freshen them up and spec springs for the Butler hyd roller turbo cam.my built on this engine is in the boost section a couple years back......Charlie the turbosmart
Hypergate45 has worked flawless.I must have did something right....thanks |
