Old 11-27-2020, 10:13 AM
PONTYRAT1 PONTYRAT1 is offline
Default SPEEDMASTER HEADS
Just saw on speedmaster site Black Friday sale
https://speedmaster79.com/Pontiac-38...-Cylinder-Head
Old 11-29-2020, 01:27 PM
gillyiowa gillyiowa is offline
Default Heads
I see theyvlist two complete heads. What is the difference?
Old 11-29-2020, 01:41 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
One if for a Hyd Flat Tapped Cam, the other a Hyd Roller.
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
Old 11-29-2020, 03:01 PM
Default head
I would be better ordering a flat tappet cam and can upgrade to roller later right? but if i order roller,I have to stay roller right?
Old 11-29-2020, 03:14 PM
Johnny406's Avatar
Not exactly, you can order the hyd roller and they should be about right for a moderate Solid Flat Tappet cam.
Old 11-29-2020, 06:41 PM
PontiacJim1959 PontiacJim1959 is offline
I was looking at the bare heads as they seem to be a good price. I did a little internet searching and as usual, mixed comments, but what I would do if you buy the heads complete is to take the heads to a machine shop and let them disassemble, clean, check valves/valve seats, and spring pressures.
Not a bad deal complete, but buying them bare would allow you to build them the way you wanted and matched for your engine specs. I don't know if this may actually wind up costing you more, but you would know what you have - just my opinion.
Old 11-30-2020, 01:27 AM
Brian Baker's Avatar
Has anyone ever flowed these heads and do they flow comparable to out of the box, unported E-heads?
Old 11-30-2020, 02:43 AM
pontiacjeff pontiacjeff is offline
Holy ****, 1200/pr, complete???
Jeff Ianitello
Old 11-30-2020, 02:54 AM
Default heads
i tried ordering,kept getting error messages and of course,they are closed on the weekend
Old 11-30-2020, 10:14 AM
RPM Speed Shop Indy
Other Shops Sell Ported 240CFM Iron Heads for $1995. Save Some Weight, Money And Gain 49CFM. Our Heads Flow 289CFM As Cast!
Priced to get you Cruising instead of Dreaming at $795.00 Each with Free Shipping!
"Buy It Now" and we'll also include a full set of Guide Plates FREE!
Bare Round Exhaust Port Head with Seat and Guides. No Valves, Valve Springs, Retainers, etc.
Valve Lift Intake Exhaust
.100 76 72
.200 147 124
.300 213 156
.400 258 177
.500 269 195
.600 289 202
CFM on Superflo SF600 @ 28"
Old 11-30-2020, 12:11 PM
Mike Davis's Avatar
I got a set last year, they were spot on out of the box, 72cc, and flowed what was stated and what Randy Repp had posted as well.
With a very light clean up they flowed 300CFM. Castings look really good. Waiting on pistons to go on a 428 street engine so no results yet.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
Old 11-30-2020, 12:49 PM
misterp266's Avatar
No, $1140. for one head.
" Darksiders Rule "
Old 11-30-2020, 01:03 PM
mysticmissle's Avatar
no it says pair down below in the description. I was able to order a set this morning. I forgot to get the guide plates so if you try to order again, make sure you include them.
Old 11-30-2020, 02:34 PM
Ya, I saw that. So you got a pair for $1200?
Jeff Ianitello
Old 11-30-2020, 03:38 PM
I just ordered sometime this morning but that is my assumption yes one pair of heads for 1100 and change plus damn tax
Machined for O-Ring: No
Heat Crossover: No
Quantity: Sold as a pair.
Calculator Compression Calculator
ORDER DETAILS
PCE281.2165
Pontiac 389 400 455 215cc 72cc Ram Air IV Hyd-R Complete Aluminum Cylinder Head
UPC:840136532415
Quantity:1
Unit Price:$1,114.70
$1,114.70
Old 11-30-2020, 03:55 PM
misterp266's Avatar
So does that mean a pair of bare heads is only $478.50?
Seems pretty cheap!
I would buy them bare and then use good parts.
JMO
Edit, bare heads are sold individually. . .
" Darksiders Rule "
Old 11-30-2020, 04:48 PM
bluegoat65 bluegoat65 is offline
Does anyone know how their oil drain back holes are located?
Old 11-30-2020, 04:52 PM
blueghoast's Avatar
I bought a set a few minutes ago and I bought a set a while ago.
I won't buy another set of eddy's again the speed master is a better head
All the way around. Good parts long valves, just so much better then the
Edelbrocks. I ported a set myself and got over 300 easy.
Just do it, Buy the SM heads and be glad you did.
GT.
Old 11-30-2020, 04:53 PM
blueghoast's Avatar
Same as eddy's
GT
Old 11-30-2020, 05:13 PM
slowbird's Avatar
slowbird slowbird is offline
Seems pretty cheap!
JMO
$960 for the pair bare is tempting!
